Coolant leak???
Old Mar 1, 2012 | 04:35 PM
japaleno's Avatar
japaleno
Coolant leak???
Ok, I was just doing the EBPS cleaning, everything went well, lots of soot cleaned out. Then I noticed the drips. I figure it's either ATF or coolant. Recently changed to red coolant from green. I'm thinking it's the coolant because I've noticed the overflow coolant tank getting lower. A regular Sherlock Holmes, huh? Wondering where it could be leaking from
Ok... again.. I tried to attached pics. but apparently not quite smart enough
So I've created an album with the pics. in it. Sorry to make this difficult, thanks for everyones help!
Last edited by japaleno; Mar 2, 2012 at 12:22 PM. Reason: OK.. got the picture thing worked out.
Old Mar 2, 2012 | 12:25 PM
japaleno's Avatar
japaleno
Pictures are posted now, anyone have any ideas?
Old Mar 2, 2012 | 12:35 PM
trekbasso's Avatar
trekbasso
DJ, did you drain the block when you changed coolant? Check the plug above the starter?
Maybe clean off real good and look toward the head area?
How many miles?
Be sure it is coolant, but looks like it.
Old Mar 2, 2012 | 12:47 PM
timmyboy76's Avatar
timmyboy76
japaleno...do you have the /AC mod withthe Ranger valve? If so, check to make sure your selector setting isnt on MAX, AC, or OFF. With my switch in ANY of those settings, the pressure is too great, making it leak from the valve, looking just like your pics, under my truck.
Old Mar 2, 2012 | 01:51 PM
japaleno's Avatar
japaleno
How many miles?
No, I didn't drain the block, but I did flush and drain the rad. like 6 times. It has 160k miles.
Yes, I do have the 'Max A/C from DieselSite. I wiped my hand around the valve, but didn't see anything.
COVeteran
Nov 20, 2017 12:59 PM
2fifty
Oct 28, 2017 04:49 PM
Coronado
2009 - 2014 F150
Jan 25, 2015 03:37 PM
cscott952
Oct 27, 2011 11:41 AM
Firefighter 1406
Feb 18, 2011 08:39 AM
