RPMs while towing
Old Mar 1, 2012 | 03:01 PM
kenn322's Avatar
kenn322
RPMs while towing
So while I wait for my radiator to get replaced, I thought I would ask this question, When towing my fiver (10500lbs) I usually run about 1950 on the tach. Seems a little high, My last truck would run about 1500 or so. It was a 5.9 with a 3.73 rear, This F350 is a 4.10 rear. I get about 10 mpg towing and my Dodge got around 12. I realize this is a bigger truck and all, Does this all seem normal? or should I be getting a little better on the MPG. Truck is stock, no deletes yet.
Thanks.
Old Mar 1, 2012 | 06:48 PM
RV_Tech's Avatar
RV_Tech
Thanks.
Lot of variables in the equation. I don't see any problem with your numbers.
Steve
Old Mar 1, 2012 | 06:50 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
At what speed are you getting 1950 revs? On my '05, I'm at 2000 at 70MPH. Or dang close to it.
Old Mar 1, 2012 | 06:53 PM
kenn322's Avatar
kenn322
I generally tow at 60-63 mph.
Old Mar 1, 2012 | 06:56 PM
RV_Tech's Avatar
RV_Tech
Tire size and rear end ratio also play a role in determining RPM. I think your numbers are withing normal drivetrain variance.
Steve
Old Mar 2, 2012 | 08:10 AM
senix's Avatar
senix
It is setup for max torgue which If I recall is made at 2K rpms.
I have 3.73 gears and at 65 I am running around 1800 rpms.
It is right where it should be with the 6.4.
Old Mar 2, 2012 | 08:14 AM
stemo76's Avatar
stemo76
Thanks.
I have a 99 PSD F-350 DRW with 4.10 as well. I run just over 2k at 65mph and get 10 mpg pulling a 5th wheel or camper and trailer. I am under the impression I should get better than 10 but it seems a lot of us end up at that mark.
Old Mar 2, 2012 | 04:33 PM
rattleNsmoke's Avatar
rattleNsmoke
You are fine. I get an average of 12mpg towing at 65mph with 3:73 gears. I plan on swapping out to 4:10 gears fr and rr when I install a Detroit Locker.
Mike
Old Mar 2, 2012 | 05:42 PM
kenn322's Avatar
kenn322
Thanks for the replies, Good to have something to compare by. I would love to eek out a few more MPGs but since it's near what my Dodge got, DW aint to mad... lol
sgeorge
All Things Towing
19
Feb 21, 2025 02:06 PM
SemperFiDevilDog
All Things Towing
33
Sep 4, 2008 01:41 PM
Big tmiller
Jun 18, 2007 09:22 AM
Capt Skip
Oct 7, 2003 04:00 AM
carpe_diem
All Things Towing
Jul 5, 2003 01:12 AM
