Possible bad thermostat
Old Mar 1, 2012 | 02:23 PM
Gmangh15's Avatar
Gmangh15
How do you know when or if it's goin bad?
Old Mar 1, 2012 | 03:13 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Need to check with a gauge. Not sure if the dash one will show just where it stands.
Like a Scanguage II, Edge Ct, or torque app. Something along those lines.
If you do have something to check temps with, it should reach 188*- 190*f. After a long drive.
Old Mar 1, 2012 | 04:38 PM
Gmangh15's Avatar
Gmangh15
I have a sg 2 how do I check it?
Old Mar 1, 2012 | 04:40 PM
amdriven2liv
The gauge is *fWT on the Scangauge II. Scroll through your gauges until you get to it. It is very accurate. *fWT is the Same as ECT for future reference.
Old Mar 1, 2012 | 04:41 PM
69cj's Avatar
69cj
192 to 204 is more realistic for a properly functioning t-stat after a 15 to 20 mile highway drive..
Old Mar 1, 2012 | 04:47 PM
amdriven2liv
I rarely see 192* this time of year. 45* and running empty at 60, I'll run 190* then 188* when I lift my foot.
Now, later this year, I will see 192*-194*. But that is at 70*+
And this summer towing? I will see 218* with the trailer on and cruising up the pass.
Old Mar 1, 2012 | 04:51 PM
69cj's Avatar
69cj
I'd say your t-stat is a little on the sluggish side.
Old Mar 1, 2012 | 04:52 PM
Gmangh15's Avatar
Gmangh15
Ok thank you my t stat is good it looks like I need a new oil cooler. Where can I order one and how much???? And not ford house
Old Mar 1, 2012 | 04:53 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Riffraff Diesel: Ford OEM Oil Cooler
Tousley Ford just barely beats Clay by $10. Both are good to deal with.
http://tousleyfordparts.com/
Don't know if either come with gaskets
Old Mar 1, 2012 | 05:03 PM
Ian123's Avatar
Ian123
81 degrees today I was running at 190 ect 194 eot unloaded on the highway. Is my t-stat bad?
Old Mar 1, 2012 | 05:13 PM
69cj's Avatar
69cj
Not bad. How many miles highway? It takes 15 to 20 miles highway to totally saturate the system. It's a hair on the cool side but not bad. People sweat too much over 2 to 4 degrees. Your delta looks real good if the system was heat saturated. Remember, a diesel has no spark plugs so the higher the temp. in the proper range the more efficient it will run. It relies on temp. and compression to ignite the fuel.
Old Mar 1, 2012 | 05:27 PM
Ian123's Avatar
Ian123
Only about 8 miles, but ECT was already at 160 degrees when I got on the highway. And yeah, I'm really surprised at how good of shape my oil cooler is in, considering its got 71k on it and used Ford gold coolant all its life.
Old Mar 1, 2012 | 06:03 PM
69cj's Avatar
69cj
Doesn't sound like the system was totally saturated to me.
Cougar54
Jun 30, 2018 10:24 PM
easyridin
Aug 29, 2015 05:24 PM
bgab3
Feb 2, 2013 09:07 AM
LARIAT 85
20
Oct 13, 2010 06:02 PM
i1dery
56
Oct 28, 2008 12:54 PM
