Temperature Gauge Reading Low
I am working on a 1950 original gauge cluster. I have converted the truck wiring to 12V but am using a solid state 12 to 6 volt reducer from D. Carpenter. The output of the converter is set to about 5.8V. I have the original style temperature sending unit (new) and a 160F thermostat. The temp gauge when the engine is at operating temperature (160F verified with an infrared temp probe) is just a shade higher than the cold reading. I expected it to read about half way between the "C" and mid-gauge since 180F is normally half way. Could the slightly low voltage of the converter be the problem? Anyone else see a low temp gauge reading and found the problem? Any suggestions?
You should shoot for an operating temp of at least 180, or you'll create sludge.
I have a solid-state regulator and set it at 7.2 volts, which is what a 6v gen puts out at cruise speed. Honestly, the gauges don't seem very sensitive to voltage, which is one of the virtues of the King-Seely type gauges.
OK, then your theory is that the gauge is probably OK, it's the engine actually running too cool. I ordered a new 180F thermostat so I'll give that a shot. If that reads at least to the 1/4 point, that will work for me. I hope this works!
Thanks, Pete but I already have one myself. That is how I verified that the problem was in the gauge setup and not my engine actually not heating up. I ordered a 180F thermostat and will install to see where that temp puts the gauge and then go from there.
BIGskinny
08-20-2011 05:50 AM
LARIAT 85
20
10-13-2010 06:02 PM
