March, 2012 Junk Yard Wishlist
This was a neat idea, thanks again to lgwilson for suggesting this!
Last month's will be unstuck & closed.
Post your wants & needs here, even if they were on last month's list; there's enough chatter on the old one it gets hard to know if somebody is still needing a part or not without reading through the entire thing.
Please keep monetary-transaction talk amongst yourselves - in PMs or e-mail.
It's fine if we want to give/sell things to each other but we can't be running a Flea Market or Auction House here, that's against the spirit of what we do here - people helping each other.
You might also check out the 80-86 Truck Parts - Free to a good home thread.
-chris
-chris
Still looking for an 83-86 Hydraulic clutch setup. I need the pedals and the aluminum "box" under the dash that holds the pedals. The Clutch master on the firewall would be nice too.
I'm willing to pay cost + shipping and for some pizza & beer.
Hey guys i need some serious help ASAP. i blew a U-Joint yesterday (one on the rear end) and long story short, my driveshaft fell out and disappeared. Ive gone everywhere i can think of, junkyards, auto parts stores, even the dealership. and NOBODY around here has the driveshaft i need. It's for a 1985 F150, 300i6, T18 4spd, 4x4, 133" wheel base. The shaft is a slip yoke connection on the transfer case end, and the rear end has a 'removable carrier'
Thanks in advance, Matt
EDIT: found one in a junkyard in CT so I SHOULD be all set
1986 F250 Lariat Stock Hub cap?
As you can see below, I'm missing the front stock hub cap. Anyone recently upgraded their rims/wheels that have the stock hub-caps lying around? Thanks, Tony in Sebastopol, CA
351M is the only other engine I believe it to work on. Won't find much FE parts in 80-86, discontinued around 76. Used to have some of that stuff, but long since gone. Did see a tripower FE intake and carb setup, the funny part of the ad said new from the 60's.... they were apparently smoking a little something in that they wanted $1750 for it as well. Sure, all new in the box, might bring some coin, but that is a bit much, especially advertising just locally.
With heat already starting in Alabama I'm going to need a/c components and hoses for a 351w that uses the new refrigerant. I'd rather buy used than new. Guy before me took it all off and I was ok in PA but AL is unbearable in the summer.
I have A/C components from My 351W removed late last year. Don't know if the compressor works because I never used it. Don't know what it would cost to ship to AL, but the price is right, because I don't need it. Let me know what all you need. PM if you can, or re-post if not and we can try e-mail,if your're interested.
Looking for a rebuildable condition Autolite 4100 1.12v carb. I've never been really happy with my Holley 4160, and I want to try something different. JY finds that look to be servicable, or trades considered.
And for you guys that are up on these carbs, which 4100 do I need to look for, for my 85 351W w/C6 trans and Edelbrock Performer manifold?
Thanks!
Thanks!
Autolite 4100
Thanks!
Thanks!
Parts needed
I'll post this again since the month is still young.
1. Need F350 emblems from a 87-91 front fender.
2. Need cruise control throttle cable for a 93-97 460 engined pickup, if a junkyard won't sell the cable separately, if it's reasonable, I'll take the whole cruise control.
3. fuel filler necks and hoses from a 87 up DRW pickup, I don't think they have to be gasoline for my use.
Thanks,
Thanks,
Looking for a set of engine perches for a 289. 2wd
Can use perches from:
1969-79 F100 w/302
1975-79 F150 w/302
1977-79 F100-350 w/351m/400m
PM email or call
facmgr@gen-aircraft-hardware.com
805-610-0475
Thank you
1969-79 F100 w/302
1975-79 F150 w/302
PM email or call
805-610-0475
Thank you
