Parking lights
Old Mar 1, 2012 | 09:56 AM
dennisb56's Avatar
dennisb56
Parking lights
I am probably just being stupid, but I can not figure out how to remove the standard parking light sockets on my 52, to replace them with a dual element socket so I can add some 1157 bulbs for both parking and turn. The socket assembly seems to be welded to the parking light metalwork. I am sure that this has been done. Any tips on this?
Thanks
Old Mar 1, 2012 | 10:15 AM
55F250's Avatar
55F250
AirForceVet
Thanks
I did mine a long time ago, if I remember correctly there is a lip on the socket that is folded over on the reflector, I used a screwdriver to pry it up and pulled the socket out of the reflector. I used scockets out of a 1969 Ford XL,worked great, just make sure you have good metal to metal contact to get a good ground, aslo my truck is a 55 not sure how different the two are.
Old Mar 1, 2012 | 10:20 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Mine were spot-welded to the frame of the light; grabbed the socket tube with pliers and twisted them, they came out with some further yanking.
Old Mar 1, 2012 | 10:27 AM
Doc's Avatar
Doc
I can't remember exactly how they are mounted. But I do remember that I looked at mine and decided to go another (cooty bob) route. At the risk of hijacking your thread, I'll tell you what I did as a shortcut, and it worked like a charm. Get yourself some of these.
And then look at the double filament bulbs you're wanting to use. They'll have 2 retaining pegs on the base (one on each side). One of those 2 pegs will work in the stock socket. The other one blocks it. Very carefully, grind off the peg that won't work (I actually touched mine to a grinding wheel and knocked it off in about one second. Just be careful.). The other remaining peg will hold it in place plenty good enough. I did this when I switched mine to double filament last summer. I haven't had a problem since. Given, the bulb isn't as tight as it should be in the socket, but so far so good. If it doesn't work, you can always go back and switch out the sockets.
Old Mar 1, 2012 | 11:14 AM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
I went the same route as Doc, except I used a drill to modify the socket to accept the offset alinement pins. I had some moisture problems at first, but put shrink wrap around the socket and it was good to go.
Sorry, to pics of the modification.
Old Mar 1, 2012 | 11:53 AM
dennisb56's Avatar
dennisb56
hey thanks guys, at least I have some ideas of how to go with this. Appreciate it!
Old Mar 1, 2012 | 03:37 PM
Doc's Avatar
Doc
Another FTE member encouraged me to share this discussion with you guys. Long story short, they discovered that an older style "1176" bulb can be used because both pins are adjacent to each other at the bottom of the bulb and not staggered like an 1157 bulb.
Bulb number - Canadian Rodder Hot Rod Community Forum
Old Mar 1, 2012 | 06:02 PM
rhopper's Avatar
rhopper
I went to napa and bought some basic 1157 two wire sockets. I posted the napa part number a year ago but don't remember what it was. They both snapped into a properly sized hole and had two ears for screws or rivets. I first removed the oe socket. After drilling the hole large enough in the light, I snapped the sockets in and pop riveted the ears. A step drill worked great for enlarging the socket hole. With two wires for the filements you'll have to run a separate ground wire.
Old Mar 1, 2012 | 09:52 PM
49fordpickumup's Avatar
49fordpickumup
Remember to place the socket so the filament stands verticle. The bulb will last longer. Run a ground wire. chuck
Old Mar 2, 2012 | 05:10 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1157's & 1034's are 12V double filament bulbs. 1034 has slightly less candle power than 1157.
1154's are 6V double filament bulbs / 1154's use the same double filament sockets as 1034/1157's.
Old Mar 6, 2012 | 04:19 PM
Cabledude's Avatar
Cabledude
It never ceases to amaze me, just when I am starting a new task on my 54 I find a thread with useful info about it. I just pulled my headlight and clearance light apart last weekend and was debating how to convert to clearance/turn signal. Thanks for the input.
Old Mar 6, 2012 | 04:44 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I can see why that would work, more vibration resistant. I'd swear every factory setup puts them horizontal.
Old Mar 6, 2012 | 05:54 PM
dennisb56's Avatar
dennisb56
I picked up two new sockets and some 1157 bulbs yesterday and I hope to get to this in the next couple of days.
51phil
Oct 29, 2010 07:57 AM
dadgonebroke
31
Sep 14, 2008 03:35 PM
52'F-3
Jul 7, 2008 05:44 PM
GreatNorthWoods
Mar 23, 2003 07:28 AM
petem
Feb 27, 2002 06:03 PM
