Two Questions: Real Excursion Questions!!!
Old Mar 1, 2012 | 02:32 AM
Fuha's Avatar
Fuha
I keep it short i have searched and didnt find anything i was looking for but did look through every result.
1) Door Lock Actuator- What is the voltage going to the Actuator suppose to be?
2) 2000 V10 4x4 Stock height measure and the crest of the fender well? I am tring to find/figure out how much lift there is on my X.
I try to get some pictures of it 2marrow of the suspension so you can help me. I know the rear leaf springs have 8 leafs and it also has blocks under that. As far as the front it has shackles.
Old Mar 1, 2012 | 07:09 AM
pdombrowicki's Avatar
pdombrowicki
The locks are 12v and the actuator for the lights are a grounding system.
Old Mar 1, 2012 | 08:57 AM
Sunline Fan's Avatar
Sunline Fan
Excursion Fleet Manager
I don't remember the measurement of mine and just have handwritten records, but remember, the measurement is all dependent on the tires. I believe the 265's all vary a tiny bit between brands/models. I'm not sure how much this would affect a fender height though. But you definitely need someone with 265's and not 285's on a stock suspension.
Old Mar 1, 2012 | 09:39 AM
JimPat's Avatar
JimPat
I believe mine was 37 and change and very low 38" before I re-sprung it.
Old Mar 1, 2012 | 10:31 AM
jasonodsky's Avatar
jasonodsky
If you measure from the center of the wheel hub up to the fender, that will give you a more accurate lift calculation regardless of tire size.
Old Mar 1, 2012 | 11:26 AM
Fuha's Avatar
Fuha
Thanks.. I was figuring it might be 12 but wanted to double check before I put a DVOM on it.
Old Mar 1, 2012 | 11:35 AM
LivingLarge's Avatar
LivingLarge
My stock height was 23 front and 24 rear... From center of hub to fender.
Old Mar 1, 2012 | 04:03 PM
Fuha's Avatar
Fuha
From the Ground to the center of the wheel well is 45 back and 44.75 on the front
Center of hub front is 28 3/4 and the same on the back
Old Mar 1, 2012 | 05:25 PM
LivingLarge
FYI... My front springs were sagging when I measured last year.
ChunderDownUnder
Australia Chapter
Nov 26, 2016 11:42 PM
Jul 13, 2009 12:19 AM
gixermann
Mar 22, 2009 10:21 PM
superbepro
Nov 15, 2007 09:37 PM
2000 ltd 10
Sep 13, 2004 05:16 PM
