Whoops! Not Good!
Old Feb 28, 2012 | 10:04 PM
mblanken881's Avatar
mblanken881
Should I just do this plus the housing?
Diesel Performance Parts | EGR Delete Kit With Oil Cooler | Ford EGR Delete Kit
How about STC fitting while I'm in there?
Old Feb 28, 2012 | 10:09 PM
m-chan68's Avatar
m-chan68
Originally Posted by BLADE35
He stripped the oil cooler housing where the Oil Pressure sensor went
So Mike if you have a good fix for that you might could save him a bunch of work
never mind I gotcha
the part number you have is for this peice right????
3C3Z-6881-AA
Pictures are worth 1000 words. And yes, 3C3Z-6881-AA is exactly the part illustrated above.
Old Feb 28, 2012 | 10:11 PM
BLADE35's Avatar
BLADE35
You will still need the part I posted in the pic
But yes that egr deleate is just like mine workeed Great but look around IIRC you can get that Deleate kit for around 150.00
and would be a great time for STC fitting your on your own for Part #s They change them so fast I give up
Old Feb 28, 2012 | 10:13 PM
BLADE35's Avatar
BLADE35
Thanks Mike Im Glad your on top of things
Old Feb 28, 2012 | 10:15 PM
mblanken881
The egr delete I posted included an oil filter also which is why it's 469.
Old Feb 28, 2012 | 10:17 PM
jl4407's Avatar
jl4407
I just found what your looking for on eBay fo 99$, not sure what ford charges but worth taking a look at.
Old Feb 28, 2012 | 10:18 PM
mblanken881
Help me create a list of everything I need:
Egr delete kit - from custom diesel
Oil cooler housing - dealer
STC fitting - dealer
Turbo oil drain tube - 6C3Z-9T515-A
Turbo gasket kit - 3C3Z-9T514-AG
Anything else?
Thanks for all your help guys!
Old Feb 28, 2012 | 10:19 PM
mblanken881
I saw that one plus a used one for $50.
Old Feb 28, 2012 | 10:25 PM
garndog's Avatar
garndog
EGR delete i did a couple weeks ago i got for 150$ included everything,from diesel performance. pretty easy too. wish i would have known about the STC update then. oh well out comes the turbo again. HAHA
Old Feb 28, 2012 | 10:30 PM
Roasted7's Avatar
Roasted7
A helicoil will fix that thread just fine.
Many military applications require helicoils in all threads.
They are reliable.
Old Feb 28, 2012 | 10:37 PM
mblanken881
They are reliable.
I've always wanted to do the egr delete anyway. Gives me an excuse to spend the money and time.
Plus, I've had some other issues like jerking/stuttering/shaking, etc. Hoping that maybe some of this stuff may help, such as the STC fitting. Maybe not but worth a shot.
Old Feb 28, 2012 | 10:39 PM
mblanken881
Benny,
I don't need the oil feed tube, do I? Can't I reuse the one I've got?
Old Feb 28, 2012 | 10:45 PM
  #28
NewToDiesels's Avatar
NewToDiesels
I have a oil cooler housing cover that I took off my late build 04 when I replaced the cooler with a BPD unit. If you need it, PM me and we can work something out. I don't think I'll need it again.
Old Feb 28, 2012 | 11:43 PM
  #29
BLADE35's Avatar
BLADE35
Benny,
Turbo Oil Feed right ??????
Yes you can reuse the one you have the braded line
The newer one is a solid 1 peice design but last time I looked it was outragiously priced
they also have an updated turbo drain alittle less restrictive for IIRC 40.00 but
Iv never had a problem with the OEM lines so I didnt do either
Old Feb 28, 2012 | 11:53 PM
  #30
mblanken881
I have an oil cooler housing coming my way thanks to NewToDiesels.
Is it possible to simply replace the housing without doing the oil cooler? Or is it worth it to get the egr deleted and STC fitting replaced?
