Source for Window Runners
Old Feb 28, 2012 | 02:24 PM
Morg89's Avatar
Morg89
I'm sure it has been asked many times but does anyone have a good source for window runners. My 84 F-150 has no felt or rubber and the window rattle is driving me crazy (er)..Thanks
Old Feb 28, 2012 | 02:33 PM
lavatan's Avatar
lavatan
You can try LMC truck (Truck Parts and Truck Accessories for Chevy, GMC, Ford and Dodge Trucks from LMCTruck.com). A good JY might have serviceable runners for you to scavange as well. That would be the cheapest way to go.
Old Feb 28, 2012 | 02:48 PM
ctubutis's Avatar
ctubutis
People like the stuff from Blue Oval Truck Parts, too.
Old Feb 28, 2012 | 03:02 PM
Morg89's Avatar
Morg89
Thanks
I'll look at both sites. Thought about the JY route but if new parts are fairly cheap.. That is one good paint job lavatan....
Old Feb 28, 2012 | 03:14 PM
WilleyJoe.62's Avatar
WilleyJoe.62
Rock Auto, too. I got my "Belt Weatherstrip/Window Scraper Seals" from them - they're the strips on either side of the window where your elbow rests when the window's down. Located under "Body-Exterior" for your truck, $9-$10 per piece.
Old Feb 28, 2012 | 03:23 PM
Morg89's Avatar
Morg89
Thanks
I'll check them out also. With spring almost here I need to be able to keep my window down. Right now I just have it rolled up real tight to keep the rattle down...
Old Feb 28, 2012 | 03:51 PM
Rogue_Wulff's Avatar
Rogue_Wulff
I bought my glass run channels at LMC, since I happened to be in KC anyways. Best money I ever spent.....
The fit was pretty good, and install was fairly easy. No more rattling windows, or wind whistle.
Old Feb 28, 2012 | 04:41 PM
smashclash's Avatar
smashclash
I bought mine from bronco graveyard. No regrets.
Old Feb 28, 2012 | 06:40 PM
Cienega32's Avatar
Cienega32
Did you get the full window set with the vertical runs and the door/window seals "where your elbow rests"?
Old Feb 28, 2012 | 07:32 PM
smashclash's Avatar
smashclash
just the elbow pieces. (the horizontal pieces that fit in between the door and window both inside and out).
Old Feb 28, 2012 | 07:42 PM
Cienega32's Avatar
Cienega32
Thanks. I was going to order a set from BGY myself .
Pitcrw6
15
Dec 7, 2011 08:26 PM
f-150 on 22's
2004 - 2008 F150
Sep 4, 2007 09:11 AM
Steve_Uzi
Aftermarket Products
Jul 21, 2006 12:01 PM
Dutch123
1978 - 1996 Big Bronco
Nov 16, 2004 12:49 AM
mptruck
May 4, 2002 12:22 AM
