Dana crate axles
Old Feb 27, 2012 | 08:51 PM
4wydnr's Avatar
4wydnr
Dana crate axles
I saw a small article on Dana crate axles in a magazine and wondered if anyone had inquired if they are making the 78-79 front 60s again. If so what do they cost?
Here is a link
Dana 60 Axles | Crate Axle
Old Feb 27, 2012 | 11:36 PM
piratius's Avatar
piratius
Those look like straight up Dana fronts. They can probably cut the tubes to whatever length you need, and then you'd just weld the appropriate spring perches in to make them fit whatever you want to put them under.
So yes. You'd be paying a lot for them, but you can probably get them to make one to fit.
Notice the tubes don't have any bracketry installed on them (spring perches/suspension link mounts/swaybar/etc)
-Brad
Old Feb 28, 2012 | 07:12 AM
Stinky7-11's Avatar
Stinky7-11
They also use a unit hub bearing instead of the serviceable tappered rollers and ball joints instead of kingpins IMO two good reasons to find a 78-79. Bet they are $$$
84 f250 6.9
Jul 8, 2010 10:44 PM
scatgo
21
Dec 17, 2008 01:31 PM
atillett
17
Jan 17, 2008 09:25 AM
blanes
Nov 8, 2007 04:48 PM
padd77
1966 - 1977 Early Broncos
Apr 1, 2003 01:06 AM
