Sponsored by: Real Truck
Noob Bolt pattern question
Old Feb 26, 2012 | 05:54 PM
Kdr358's Avatar
Kdr358
I tried searching but I can find what im looking for. I have a 2000 F350 SD CC V10 date code is 05/00. I have the coarse thread m14x2.0 studs. I got a set of aftermarket rims from a 2001 ish E250 SD with fine threads and the rims dont bolt up and are about 1/8th off. Is the bolt pattern the same or do I need early 99-00 F series rims? Thanks.
Old Feb 26, 2012 | 07:07 PM
Rongold's Avatar
Rongold
RIMS
You already answered the question. You got the wheels from an Econoline. Evidently, the bolt pattern is different. I think the only difference between early and late F series pickups is the thread pitch on the studs. You need late 99-2004 F series 250-350 rims on a 2000 F-350.
RON
Old Feb 26, 2012 | 07:29 PM
PA-Mark's Avatar
PA-Mark
im 99% sure thred pattern is 14X1.5 btw and bolt pattern should be 8X170 mm
Old Feb 26, 2012 | 07:44 PM
kd0axs's Avatar
kd0axs
What you need is a set of wheels for a 99-04 Super Duty pickup. The vans don't have the metric bolt pattern that the SD has, they have the old bolt pattern like the pre-1997 trucks.
Old Feb 26, 2012 | 08:47 PM
Kdr358's Avatar
Kdr358
I just figured like all old stuff 8 lug ford rims were all the same. I guess I'm now in the market for 99-04 wheels! Excursion rims will fit as well right? Or stick with the pickup rims? Thanks!
Old Feb 26, 2012 | 09:18 PM
WE3ZS's Avatar
WE3ZS
'00-'05 Excursion rims are the same as '99-'04 Superduty rims, any SD rims '05 or later will have a different backspace and will need $pacer$ to fit an earlier truck.
Powerstrokin_350
Feb 18, 2012 04:21 PM
marine1200
1947 and Older Ford Trucks
Nov 30, 2011 04:00 PM
hans88
May 27, 2006 11:40 PM
LastStarfighter
May 2, 2006 10:27 PM
nd4spd
1997 - 2003 F150
Jun 22, 2004 09:00 PM
