So simply put, what are the rim/wheel bolt patterns on the F450 from 1999 up to 2010? are they different throughout them years or did they stay the same? 2008 f450 factory aluminum rims fit on an 04 F450?? Thanks for any info!!
They used a slightly different bolt pattern on the e99 models anything before 05/99 has a different rim/pattern I tried it before with a e99 and 05 f450 rims and they had different offsets and didn't want to bolt up.
F450 & F550's from 99-04 used 8 lug/225MM pattern. 05-12 used 10 lug/225MM pattern (except 2011-12 F450 pickups which use the smaller F350 pattern). 08 F450 wheels will not fit on an 04 F450.
I open multiple windows at once, so my brain had a chance to disconnect the title of this thread (F450 bolt patterns) from the actual post (which also says F450 in it, but that's another mental issue ).
