Fuel Line needed
Old Feb 26, 2012 | 02:34 PM
Big Reg 19's Avatar
Big Reg 19
Fuel Line needed
Hi all,
I'm looking to buy the fuel line from the fuel filter to the fuel rack on the engine.
where can I find one........even used........
over a month before I can get it from the dealer
Thanks,
Reg
Old Feb 26, 2012 | 07:15 PM
kaerch's Avatar
kaerch
can you further describe your situation...
Old Feb 26, 2012 | 07:25 PM
Big Reg 19's Avatar
Big Reg 19
I need the gas line that start from the out put of the fuel filter under the driver side door, when it leave the fuel filter it is a 90 degree metal pipe that transform into a flex line that go over the front drive shaft, then it become metal line at the transfer case all the way up the engine to connect to the fuel rack.
this is the pressure hose that bring the gas to the engine.
what happen is the u joint on the front drive shaft did broke at the transfer case and before we can stop the pick up the drive shaft damaged the gas line and started to leak.
Old Feb 26, 2012 | 07:57 PM
danorules's Avatar
danorules
I haven't bought any in years, and its a big PITA, but I have previously bent up my own fuel lines. You need the line, a Bender, a flare tool, and the ends. Fairly easy, just time consuming. If you have the old line out of the truck then you just match all of the angles and presto, you hanger a new fuel line. No waiting for a back order
Old Feb 26, 2012 | 08:52 PM
Big Reg 19's Avatar
Big Reg 19
the problem is the flex line
I can't have a solid line all the way
Old Feb 26, 2012 | 09:12 PM
danorules's Avatar
danorules
Maybe use rubber line while waiting for the flex line. I would double clamp both ends though, there is a lot of pressure in those lines.
Old Feb 26, 2012 | 09:23 PM
Big Reg 19's Avatar
Big Reg 19
I did to be able to move the truck, but the line go over the exhaust pipe also.........wery hot, I'm scared that the rubber line caught in fire
tlk401
1983 - 2012 Ranger & B-Series
Dec 13, 2022 02:50 AM
gman97005
Jan 21, 2015 05:14 AM
svt2205
2004 - 2008 F150
Jul 6, 2007 04:04 PM
DaBrick
Dec 13, 2004 06:09 PM
darren1h
Feb 16, 2004 10:18 PM
