2006 F350 No start
2006 F350 No start
My buddy has a 2006 F350 with 112,500 on the odo. He said he was driving to work this morning and it started missing/kinda getting low on power. I went to go drive it while he was working and it sat for 2 hours. I got in and it wouldnt start! Its had the STC fitng replaced 20k ago with the Updated fitting and its had the oil/egr cooler/egr valve replaced 15k miles ago. His diesel tech replaced the fuel filters and flushed the coolant 2 days ago as my buddy didnt have time to tackle the job. I pulled some codes off of it after i tryed starting it and its PO278 and P01000. What do you guys think?
P0278 is Cyl 6. An inject? Would an inject cause a no start?
When he had it in the shop 2 days ago, the diesel mechanic said that an inject is starting to go bad. He uses the same diesel mech as i do and the guys very good with 6.0s
I thought that the Edge would monitor those ICP and IPR%
I guess if not then all you can do is take a DVM to the ICP sensor you will need a minimum of 0.82 volts to start
IPR # 14.84 24 40.60 0 - 50 PERCENT Injection Pressure Regulator
ICP 0.2 1.0 1.8 0.15 - 4.7 VOLT Injection Control Pressure
ICP_DES 0 625.5 1400 - 1450 0 - 4045 PRESSURE (PSI) ICP Desired
left to right KOEO,Low Idel,High Idel 2500rpm And then Range
or post what ya get if in ?????
So its IPR, KOEO: 14.84 Low Idle: 24. High idle - 2500 rpm: 40.60. Range: 0-50 per?
ICP, KOEO: 0.2, Low idle: 1.0, High Idle - 2500 RPM: 1.8, Range: 0.15-4.7v.
Sorry they were hard to read lol
Where is the ICP sensor?
And snuggyworm, the FICM is good. Alternator i have no clue what condition its in. But the truck cranks very strong. Just wont turn over
the range is where a DTC maybe set if falls out of that spec
ICP in an 06 is in the Passengerside valve cover you can use a DVM and backprobe it you need a minimum of 0.82volts to start
Just went out to my truck and checkd. ICP is read by the CTS. Not IPR. Went up to where he works an hr ago after the truck sat all day and still wont start! So doesnt that elminate a a leak in the HPO? Im going back in the morning and gona read the ICP sensor readings.
Do you have a pict of the sensor on the passeng valve cover? If i unplug the ICP will the truck start?
that sucks
He could still have a Blown STC Fitting or a Bad HPO Leak
When you get some readings you should be able to figure what way to go
Also code scan it to and check the FICM and all you can write it down
Maybe if its only a bad ICP sensor
I dont have a Picture of it
but here is a Pic of the sensor itself
<TABLE border=0 cellSpacing=0 cellPadding=0 width=773 align=center height=1121 usegridy showgridy gridy="10" usegridx showgridx gridx="10" cool><TBODY><TR height=10><TD height=10 width=772 colSpan=5></TD><TD height=10 width=1><SPACER type="block" width="1" height="10"></TD></TR><TR height=30><TD height=1110 rowSpan=3 width=10></TD><TD height=30 vAlign=top width=200 colSpan=2 align=left content xpos="10" csheight="30">Return to Table of Contents</TD><TD height=30 width=562 colSpan=2></TD><TD height=30 width=1><SPACER type="block" width="1" height="30"></TD></TR><TR height=1050><TD height=1050 vAlign=top width=762 colSpan=4 align=left xpos="10"></TD><TD height=1050 width=1><SPACER type="block" width="1" height="1050"></TD></TR><TR height=30><TD height=30 vAlign=top width=110 content xpos="10" csheight="30">Page_060.html </TD><TD height=30 width=550 colSpan=2></TD><TD height=30 vAlign=top width=102 content xpos="670" csheight="30"></TD><TD height=30 width=1><SPACER type="block" width="1" height="30"></TD></TR><TR height=1 cntrlrow><TD height=1 width=10><SPACER type="block" width="10" height="1"></TD><TD height=1 width=110><SPACER type="block" width="110" height="1"></TD><TD height=1 width=90><SPACER type="block" width="90" height="1"></TD><TD height=1 width=460><SPACER type="block" width="460" height="1"></TD><TD height=1 width=102><SPACER type="block" width="102" height="1"></TD><TD height=1 width=1></TD></TR></TBODY></TABLE>
