ScanGauge II codes
Old Feb 26, 2012 | 08:27 AM
rattleNsmoke's Avatar
rattleNsmoke
ScanGauge II codes
I've been using my ScanGauge II now for almost a year with decent, or what I thought were decent results. Recently I've found threads that state different codes for ECT and EOT. How do I determine what the proper series of codes should be for my 2006?? I haven't a clue what flash was done last on it, or if that makes any difference what so ever. Does the pre-start delta after a good overnight cold soak give any indication? I've changed the thermostat TWICE figuring I might have had a bum, brand new thermostat, and was successful in bringing it up to 186-190 deg when warmed up with a 7-9 deg delta @ 65mph straight and level. I found what appeared to be a more recent series of codes from somebody with a late '05 Excursion so I tried that creating a new ECT input. Now my ECT runs up quicker and will indicate 190-196 when warm with the ECT running a degree or three warmer than the EOT or dead equal to it. It never showed that with the old code. I let the truck cold soak last night and this morning the EOT and ECT were 8 degrees apart with the ECT indicating warmer than EOT. I thought that was weird. Sorry for the long winded scenario, but if you can direct me to the correct codes I'd really appreciate it. Without that, I can't trust the ScanGauge.
Thanks in advance
Mike.
Old Feb 26, 2012 | 09:00 AM
w_huisman's Avatar
w_huisman
It seems pretty obvious in reading your post, unless I've missed something...
Prior to changing your ECT code, your ECTs ran 7-9 degrees cooler than your EOTs.
Then, after changing your ECT code, your ECTs run equal to your EOTs, and you've noticed that your ECTs start out 8 degrees above your EOTs after an overnight cold soak.
So I'd guess your original ECT code was correct, and your new ECT code shows ECTs 8 degrees warmer than they should be.
Also, your original 7-8 degree delta (prior to changing your ECT code) is perfectly acceptable. So change your ECT code back to the original code, drive your truck, and smile.
Old Feb 26, 2012 | 09:11 AM
rschwarzwalder's Avatar
rschwarzwalder
I'd use the EOT from Scangauge's website:
TXD:07E0221310
RXF:046245130610
RXD:3010
MTH:00090005F060
And James DeLong reccomends the built in fWT for ECT.
In the other thread he lists the code used for the fWT which you can input as an xgauge and then label it ECT if you don't like the fWT look.
TXD: 07DF0105
RXF: 044105050000
RXD: 2808
MTH: 00090005FFD8
The best codes should be equal or close to equal after a good long cold soak.
If I'm the guy you mention with the 05 X, my idea behind the altered code was proven to be incorrect!
Last edited by rschwarzwalder; Feb 26, 2012 at 09:19 AM. Reason: Found the fWT code...
Old Feb 26, 2012 | 09:42 AM
rattleNsmoke
Thanks for the reply's! It's too bad the 'new' codes I input yesterday were not correct. They had a lot going for them.. I thought cool !!, after my EGR cooler and oil cooler was replaced by Ford last year, the delta is now with the new codes, 0...It don't get much better than that. Oh well, I want to be exact with my numbers forfeiting temporary exstasy.
Mike
Old Feb 26, 2012 | 01:10 PM
BLADE35's Avatar
BLADE35
By design theres no way you can have a 0 degree spread between ECT & EOT if taken at the correct time
somethings off be it a wrong SGII code or bad sensor
Old Feb 26, 2012 | 02:37 PM
GreenPSD's Avatar
GreenPSD
I had the same question. I had the SGII for about two weeks now and used the EOT off of the Scangauge website. My EOT was about 6-9 degrees higher than the ECT. I was relieved. Then I found two other EOT codes on here and got concerned. I put those into the SGII. With the truck cold, one was showing basically the same as the Scangauge website code. The other code showed about 30 degrees higher. I think that one is wrong. I will check them when the truck is warmed up.
Old Feb 26, 2012 | 02:45 PM
BLADE35's Avatar
BLADE35
I have used both original fWT and the xgauge ECT both read the same
One thing to keep in mind here is the 6.0 only has 1 ECT sensor so both ECT or fWT whatever gauge you run will be reading off the same sensor
Im thinking if you guys have a Big Diff in fWT & ECT there might be an error with the x-code programming
Old Feb 26, 2012 | 06:42 PM
rattleNsmoke
I reprogrammed it and I'll check the cold soak in the morning.
Mike
purpletruck
1983 - 2012 Ranger & B-Series
Oct 5, 2021 08:54 AM
gptco
Escape & Escape Hybrid
Sep 30, 2011 10:20 PM
Antelope V-10
Modular V10 (6.8l)
Aug 5, 2008 04:46 PM
hsejkora
Mar 29, 2007 11:12 PM
gnfshn1218
Bronco II
Oct 27, 2003 01:42 PM
