IDM fault
Old Feb 25, 2012 | 09:14 PM
stemo76's Avatar
stemo76
IDM fault
Been trying to track down some MPG issues for a long time. Today I hooked up my AE tool and ran through all the tests. Cylinder Contribution Test showed #2 and #8 faults. Ran the test about 10 times. Sometimes both faulted sometimes just 2 or 8. Thought that sucks but at least they are under the same side.
Ran the KOEO test and got a IDM fault. I have the early 99 and swapped out the IDM with a factory unit from a newer truck to get the higher voltage. Could this be the cause of the IDM fault or is there something wrong with it? If it is the IDM I guess that could be affecting the contribution tests so I wouldn't have to dig into that again.
Old Feb 25, 2012 | 09:23 PM
jkidd_39's Avatar
jkidd_39
Usually a sigh of the IDM going bad.. It will get more noticably rough idle wise over time. My dad's truck is doing this. I am gonna try one of Swamps modded IDMs. Robert6401 has one and loves his.
Old Feb 25, 2012 | 09:38 PM
stemo76's Avatar
stemo76
Guess thats good to know that this could be failing and still allow the truck to run ok.
I checked out Ebay and can get a factory 120 unit for about 125.
Confused as to why Swamps listed a factory unit for 400.00 but their modified unit for 275.00.
Is this just to show what a good deal theirs is?
Old Feb 25, 2012 | 09:48 PM
jkidd_39's Avatar
jkidd_39
don't get your IDM from Computer Exchange on EBAY.. mine went out a few years ago.. I ordered one from them.. took about 12 swaps from them to get one that worked..
The extra $125 is basically a core charge. They are hard to find now a days.
Old Feb 25, 2012 | 09:49 PM
stemo76's Avatar
stemo76
Ordered up the Swamps, hopefully this fixes some things for me.
475.00 total with 200 coming back with rebuildable core.
Old Feb 25, 2012 | 09:51 PM
jkidd_39's Avatar
jkidd_39
sweet! Let us know how it works out. Have fun swapping it. They are funnnn!!
Old Feb 26, 2012 | 07:56 AM
AMHJAB's Avatar
AMHJAB
you have to repair the injector faults first because that automatically triggers the idm fault, most likely bad injector solenoids, then after repaired erase codes and see if it comes back, i dont think it will.
Old Feb 26, 2012 | 07:58 AM
stemo76's Avatar
stemo76
I did the buzz test and they all sound even.
Old Feb 26, 2012 | 08:15 AM
AMHJAB's Avatar
AMHJAB
i would take the two injectors showing faults out and swap with the good ones and run the test again then if the same two holes show the faults its not an injector issue, but they are also known for the injector harness failures, Injectors 2 and 8 are not hard to get to.
Old Feb 26, 2012 | 08:17 AM
stemo76's Avatar
stemo76
The injectors and motor have about 10k. I replaced the under valve cover harnesses. does the external harness go bad as well?
Old Feb 26, 2012 | 08:23 AM
AMHJAB's Avatar
AMHJAB
usually just the valve cover gasket, i had the same issue with my 99 f350 and found out it was just the injector solenoids, i replaced them and erased codes and its been good for two years now. i would swap the solenoids in that bank and check again just to be completely sure that its not there, before spending money for the IDM, when the solenoids start to go bad they show up intermitently and that triggers the IDM codes
Old Feb 26, 2012 | 08:26 AM
stemo76's Avatar
stemo76
The IDM will be an upgrade anyway, so I am going to drop that in and recheck. If I still have the contribution failures then I will swap 2 and 4 and 6 and 8 and see if it sticks with the holes or the injectors. If its the injectors then I know what needs to be done. If its the holes I am going to hope its the harness, am not looking to repair the motor. Should not need to replace the motor twice in 160k.
Old Feb 26, 2012 | 08:30 AM
jkidd_39's Avatar
jkidd_39
Id say with the miles on your motor you have a bad idm. But you could ohm your harness just to make sure.
If you've never done one before I would recommend pulling it out of the truck. Much easier to test on the bench.
Old Feb 26, 2012 | 08:32 AM
stemo76's Avatar
stemo76
Is this process documented somewhere? Are you talking about ohming out from the IDM connector to the injector connectors?
Old Feb 26, 2012 | 08:56 AM
jkidd_39's Avatar
jkidd_39
I was referring to the uvch. My mistake. You just replaced it.
