bogs down in gear
Old Feb 25, 2012 | 07:05 PM
Neauxx's Avatar
Neauxx
bogs down in gear
My 76 ford van idles great and engine will rev up fine out of gear. As soon as I put it in gear the engine bogs down and will die with any acceleration. I have put a nos carb on it and it ran fine for a couple of weeks. I just put in a new rotor and cap. No help. I've had this van for years with no problems. Any ideas on what the problem is?
Old Feb 25, 2012 | 07:19 PM
HIO Silver's Avatar
HIO Silver
'Sounds like you have a vacuum leak somewhere.
BUT, what engine/trans combo are you working with and how is it equipped - AC, smog equipment, EGR, etc....??
Old Feb 26, 2012 | 12:18 AM
Neauxx's Avatar
Neauxx
boging
Stock 351W with a C6 trans. Standard smog for that year. I checked all vac. hoses and connections. I have not used a tester on the vac. yet. It does have an EGR. Have not tested it yet.
Old Feb 26, 2012 | 09:02 AM
HIO Silver's Avatar
HIO Silver
You've got more troubleshooting to do....
Old Feb 26, 2012 | 10:01 AM
critterf1's Avatar
critterf1
I would be looking at the carb.
Old Apr 14, 2012 | 06:45 PM
Neauxx's Avatar
Neauxx
I'm back. I replaced all the vacuum lines, timing is dead-on at 12 degrees, vacuum sits between 9 and 11 lbs. will come up at higher rpm's. Idle will not quite smooth out. Once engine is warmed up it turns to crap. Step on gas and it shuts down. No EGR, only smog stuff is valves on air cleaner and a "can". New carb., cap & rotor. Engine will run if the choke plate is held almost closed.??? When cold or I manually close the choke plate the engine starts right up. Call me frustrated.
John_e150
19
Oct 25, 2016 10:16 PM
gmurr
Feb 13, 2016 02:07 PM
gordo351
Nov 14, 2004 07:26 AM
Flatspins
Oct 6, 2003 11:14 AM
