Crower Cam E11724???
Old Feb 25, 2012 | 09:41 AM
meborder's Avatar
meborder
anyone know anything about it?
not familiar with specs for a big block ford, so i have no idea how "hot" this cam would be.
any info in general? looks like it might be a mechanical flat tappet?
There is a guy selling it used and could probably get it for a song. but if it is a race type cam, it wouldn't be much use to me.
crower cam card lookup says:
<TABLE border=0 cellSpacing=0 cellPadding=0 width="100%"><TBODY><TR><TD colSpan=2><TABLE border=0 cellSpacing=0 cellPadding=0><TBODY><TR><TD colSpan=4>Part Number/Work Order Number E11724
Engine Application 429 FORD
Grind Number SPECIAL ADVERTISED CAMSHAFT SPECIFICATIONS:
</TD></TR><TR><TD width="25%">INTAKE:</TD><TD width="25%">Duration: 290º</TD><TD width="25%">Lift: .637</TD><TD width="25%">Clearance Hot: .026</TD></TR><TR><TD width="25%">EXHAUST:</TD><TD width="25%">Duration: 296º</TD><TD width="25%">Lift: .644</TD><TD width="25%">Clearance Hot: .028</TD></TR><TR><TD colSpan=4>
<TABLE border=0 cellSpacing=0 cellPadding=0 width="100%"><TBODY><TR><TD>The specifications listed above are based on a rocker arm ratio of </TD><TD>1.73 IN
1.73 EX
</TD></TR><TR><TD class=hd colSpan=2>
RECOMMENDED VALVE SPRING INFORMATION:
</TD></TR></TBODY></TABLE>
</TD></TR><TR><TD colSpan=4><TABLE border=0 cellSpacing=0 cellPadding=0 width="100%"><TBODY><TR><TD width="40%">Part # </TD><TD width="20%">Single </TD><TD width="20%">Dual </TD><TD width="20%">Triple </TD></TR><TR><TD>Approximate spring pressure:</TD><TD colSpan=3>valve closed: LBS.
valve open: LBS.
</TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE></TD></TR><TR><TD width=275><!--img src="http://www.crower.com/media/images/camcard.png" border="0" alt=""/ --><TABLE style="BACKGROUND: none transparent scroll repeat 0% 0%" target="_blank" camcard.png? images media Camshafts | Connecting Rods | Roller Lifters | Rockers | Crankshafts | http:>http://www.crower.com/media/images/camcard.png) no-repeat" border=0 cellSpacing=0 cellPadding=0 width=275><TBODY><TR><TD colSpan=3></TD></TR><TR><TD class=dg width=60>20.0 BTDC</TD><TD width=156></TD><TD class=dg width=60>16.0 ATDC</TD></TR><TR><TD style="HEIGHT: 77px" colSpan=3></TD></TR><TR><TD class=dg>ABDC 48.0</TD><TD class=dg></TD><TD class=dg>60.0 BBDC</TD></TR><TR><TD style="HEIGHT: 71px" colSpan=3></TD></TR></TBODY></TABLE></TD><TD><TABLE border=0 cellSpacing=0 cellPadding=0 width=225 bgColor=#b4b4b4><TBODY><TR><TD><TABLE border=0 cellSpacing=1 cellPadding=3><TBODY><TR>camcard <TD bgColor=#f5f5f5 colSpan=2>The information below is for degreeing cam only. Correct only at .050" tappet lift.</TD></TR><TR bg************><TD width="35%">INTAKE</TD><TD width="65%">Opens: 20.0 BTDC
Closes: 48.0 ABDC
</TD></TR><TR bgColor=#fef3e2><TD>EXHAUST</TD><TD>Opens: 60.0 BBDC
Closes: 16.0 ATDC
</TD></TR><TR><TD colSpan=2 bg************>
LOBE SEPERATION 108º
</TD></TR><TR bgColor=#fef3e2><TD>Duration at .050"</TD><TD>Intake: 248
Exhaust: 256
</TD></TR><TR bg************><TD>LOBE LIFT</TD><TD>Intake: .368
Exhaust: .372
</TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE></TD></TR><TR><TD colSpan=2>
If using "Lobe Center" method of degreeing, cam should be installed on an intake centerline of: 104º NOTES:
Cams damaged by excessive spring pressure, over shimming, valve train bind or retainers contacting the guides are void from warranty. Refer to the "Important Camshaft and Lift Information" booklet included with each new Crower camshaft to avoid any break-in problems.
Old Feb 25, 2012 | 09:52 AM
1wicked55's Avatar
1wicked55
You dont want that cam unless you want to make peak HP at 6500 rpm.
Old Feb 25, 2012 | 02:49 PM
Sleepy445FE's Avatar
Sleepy445FE
That's a HOT one for sure! You'd need at least 10.5:1 to make use of it. Generally once you start getting above .575 lift and more than 236 @ .050 it won't be much good for anything but hauling a$$. Unless it's a roller, then you can get away with a bit more, but still this one is beyond that "bit more".
Old Feb 25, 2012 | 03:49 PM
meborder's Avatar
meborder
good to know! thanks guys!
ReAX
Modular V8 (4.6L, 5.4L)
Dec 11, 2012 11:56 AM
RacinNdrummin
19
Sep 23, 2012 03:08 AM
outlaw30830
1978 - 1996 Big Bronco
Apr 5, 2008 10:21 PM
Truckin4life
15
Mar 17, 2008 06:01 PM
lucky no. 7
Apr 16, 2007 09:09 AM
