1978 - 1996 Big Bronco
I put a cam in
Old Apr 2, 2008 | 07:53 PM
outlaw30830's Avatar
outlaw30830
I put a cam in
Ok i put a cam in my bronco and lifters, timing chain, wires, plugs, and my truck is running really bad i got everything tested i just need to know if i need a different map sensor because of my cam it is a Crane cam part # 130052
thx
Old Apr 3, 2008 | 10:28 AM
Kemicalburns's Avatar
Kemicalburns
we need more info man. what year/motor are we talking about. also post the spec of the cam, lob seperation being the most important thing right now.
Old Apr 3, 2008 | 10:51 AM
outlaw30830
it is a 88 Bronco
Part Number: 130052 Grind Number: 272 H10
Engine Identification:
Start Yr. End Yr. Make Cyl Description
1962 Up FORD-MERCURY 8 GOOD IDLE, DAILY USAGE, OFF ROAD, HIGHWAY TOWING, FUEL EFFICIENCY PLUS PERFORMANCE, GOOD LOW AND MID-RANGE TORQUE AND HP, 2600-3000 CRUISE RPM, 8.75 TO 10.0 COMP. RATIO ADVISED. BASIC RPM 2000-5000
Engine Size Configuration
221-302 C.I. V
Valve Setting: Intake .000 Exhaust .000 HOT
Lift: Intake @Cam 3027 @Valve 484 All Lifts are based
on zero lash and theoretical rocker arm ratios.
Exhaust @ Cam 3027 @Valve 484
Rocker Arm Ratio 1.6
Cam Timing: TAPPET @.004
Lift: Opens Closes ADV Duration
Intake 27 BTDC 65 ABDC 272 °
Exhaust 67 BBDC 25 ATDC 272 °
Spring Requirements: Triple Dual Outer Inner
Part Number 96803
Loads Closed 107 LBS @ 1.700 or 1 45/64
Open 255 LBS @ 1.240
Recommended RPM range with matching components
Minimum RPM 1600
Maximum RPM 5200
Valve Float 5800
Cam Timing: TAPPET @.050
Lift: Opens Closes Max Lift Duration
Intake 3 BTDC 33 ABDC 105 216 °
Exhaust 43 BBDC (7) BTDC 115 216 °
Remarks:
FIRING ORDER 1-5-4-2-6-3-7-8
Old Apr 3, 2008 | 11:04 AM
Conanski's Avatar
Conanski
This cam has a lobe seperation angle of 110 degrees, it's not compatable with the stock EFI system in the Bronco.
Old Apr 3, 2008 | 02:26 PM
kameronth's Avatar
kameronth
Not to steal a thread here but what is the range a cam should be in for a 302 sd system?
Old Apr 3, 2008 | 03:01 PM
Conanski's Avatar
Conanski
In general the cam needs 114 degrees lobe seperation angle or greater and less than 216deg intake duration @ 0.050". Some cams with much shorter intake duration(208 degrees and below) and 112 LSA are also know to be stable. Cam lift doesn't seem to make much effect.
Old Apr 4, 2008 | 01:48 PM
Kemicalburns
so basicly your cam needs swapped out. or you need to convert to mass air. if you would rather convert let me know i have a conversion harness for sale along with an MAF meter. just send me a pm
Old Apr 4, 2008 | 02:32 PM
Twistin's Avatar
Twistin
I put a cam in
thx
Couple of things, no one asked or hit on, was your engine a 5.0 HO? if it was then you need a 5.8 cam. the fire order is different. Or are you sure it was a 5.0 & not a 5.8 to start with? or vice versa? Ya you can try changing the fire order, but one way or the other the PCM that holds the injector fire order isnt going to deliver fuel at the right time, to the corect cylinder. OR you do have a 5.0 & the cam in the box was for a 5.8 (miss boxed) My 2 cents.
Keep Em' Twistin'! Bob B.
Old Apr 5, 2008 | 01:19 PM
Kemicalburns
with sd. the injectors are batch fired not sequential so it doesnt matter what cam is in there as long as the plug wires are matching that firing order.
if this was a stang or MAF already then injector order would need to match
Old Apr 5, 2008 | 01:43 PM
Twistin's Avatar
Twistin
I put a cam in
Then if what you said is true, then why when I worked at "Genesee Ford Truck" and customers complaned about the rough idle a 5.0 HO had, we'd change out the cam for a stock 5.0 cam AND change the PCM? and it was a pain casue we had to set the parameters & flash the PCM. A Ford delaership having all kinds of info at there finger tips, if they knew you could use the same PCM, why change it? At a dealership time is money. Just my dealings with this. I'm not sayin I know it all, just what we had to do when changing a cam at a dealership. info is info.
Old Apr 5, 2008 | 03:16 PM
Kemicalburns
are you talking in a truck or mustang. the efi is different between the 2 and so is the wiring harness. check out FFI.com
Old Apr 5, 2008 | 10:21 PM
Twistin's Avatar
Twistin
I put a cam in
mid 80's thru late 90's and trucks & bronco's. Genesee Ford Truck just sold & serviced Ford trucks vans PDV's and F series all the way thru simi's. (LTL & CTL) + Cat Cummings & fright shakers. also delt with eaton & splicer & rockwell trans & rear ends. the only mustang that came thru the shop was when George Sharp bought a stang for his dauters sweet 16 B day. that ended up going to a "car" dealership for service.
