My biggest question would be why would it run perfectly on cruise if there are issues with the engine components? New to small diesels have owned numerous big trucks but never seen this type of problem with the big boys.
That's why I asked you if it ran rough when you accelerate using the cruise control acceleration button.
You said it didn't run rough, so that makes me think it's your pedal sensors.
Pedal replaced because of loss of acceleration at take of especially and I checked around online and saw that the pedal was a common cause. I guess I could have had a bad pedal new out the box.
Unless I am mistaken and tps is somewhere else in line. My pedal and tps are one piece. The pedal deffinitely has somethong on left side which is attached and has a wire plugged into it.
