gpr woes
Old Feb 25, 2012 | 12:51 AM
farmer ford's Avatar
farmer ford
gpr woes
i just put on a new gpr and checked all fuses and relays. i have power to the gpr at all times and to the i post when the ignition is on but i cannot get power to the s terminal to charge the solonoid. any thoughts and help would be great.
Old Feb 25, 2012 | 06:40 AM
tjc transport's Avatar
tjc transport
i ain't rite
the only thing that comes to mind are cold or hot engine?
if cold, i would be looking at the temp sensor. if hot engine, you will not get energized power to the relay.
Old Feb 25, 2012 | 09:30 AM
farmer ford
ok. the engine is cold. the temp guage read out on the dash fine the other day but that probably isnt a deffinite that it is ok. how else would i check?
Old Feb 25, 2012 | 09:51 AM
Hussler's Avatar
Hussler
What relay did you buy?
As you indicated one small terminal will have power with key ON (Red/LtGrn wire) and the other small terminal (PPL/ORG) is pulled to ground by the PCM to activate the GPR. From your description is sounds like the relay is working. Does it click when you turn the key to ON?
Old Feb 25, 2012 | 12:07 PM
farmer ford
so i didnt trust the gpr i bought and ran to napa and bought the gpr 109. it started the the truck but with a test light hooked to the gloe pug post the coil is not releasing when wait to start light goes out. is my pcm not releasing the ground? are my glow plugs going to fry?
Old Feb 25, 2012 | 12:24 PM
Hussler's Avatar
Hussler
Glow plug ON time is independent of wait-to-start light. WTS light comes on for a few up to maybe 20 seconds while the GPR can stay on for up to 2 minutes. And no you won't hurt anything. You can tell when the GPR turns OFF by watching your in-cab volt meter because it will jump up when the relay turns OFF.
Here is a chart showing GPR on time vs engine oil temp ...
adam10
Apr 23, 2012 10:41 PM
timmyboy76
Oct 24, 2011 07:08 PM
joes50pu
24
Dec 28, 2008 10:56 AM
matt71
Dec 26, 2008 12:29 PM
jdecker88
Nov 5, 2007 08:32 AM
