In desperate need of a Radiator for a 64 F200
I had trouble finding a direct replacement for my 66 with a 240 originally... so i welded c brackets with rubber around the inside and went to the local race shop and spent 189 for an aluminum 28" wide one. always overheated my 300CID before that and never since. just had to use flexi hoses and remove insert plate for the wider radiator. Much more cooling with the new one and cheep too!
Please, when asking questions, list all the pertinent info. There is no such thing as an F200.
1961/64 F100/250 & F350 with SRW (single rear wheels): The 223 I-6 radiator is different than the 262 I-6 radiator. Neither is the same as the 292 V8 radiator.
Where are you located in SoCal? There is a truck wrecking yard in Los Angeles that has a gazillion different remanufactured radiators.
But you will need to take your radiator there...to match it up.
