Project: Check This Out!
Old Mar 14, 2012 | 07:11 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
Originally Posted by preppypyro
For what its worth, there was never a stock 460 in an f150 in that year.
ford put a 460 in a f150 in some other year(s)?
Old Mar 14, 2012 | 08:32 PM
Tsoptich's Avatar
Tsoptich
Tomorrow I am going to call the Local JY and get a driver side exhaust manifold to use for now. I want to get the truck running before I throw upgrades at the truck. Pulling it in the shop friday.
Old Mar 19, 2012 | 12:19 AM
Tsoptich's Avatar
Tsoptich
Last night I got the truck in the shop and starting getting things ready to get the motor dropped in. Come to find out there are some things that I need to get. So instead of working on the truck I made a list of what I need to get or want. Here are some pictures as well:
1) Motor Mounts- JBG
2) Motor Mount Hardware- JBG
3) Valve Cover Gaskets- Autozone
4) Upper Intake Gasket- Autozone
5) Oil Pan Gasket-AutoZone
6) Timing Cover Gasket-Autozone
7) Spark Plugs
8) Cap & Rotor
9) Spark Plug Wires
10) Serpentine Belt
11) Battery
12) Door Locks
13) Oil Filter
14) Trany Filter & Gasket
15) Radiator- Hot Tanked and Checked out OK
16) Windsheild
17) Seat Belts
18) Seat Bolts
19) Front Brakes
20) Rear Brakes
21) Shocks
22) Trany Cooler
23) Exhaust System
24) Hi-Flow Cats
25) D/S Exhuast Manifold- Napa
26) O2 Sensors
27) Ball Joints
28) Tie Rods
29) Wheel Bearings (Cleaned and Packed)
30) Air Filter
31) Front Axle Seals
32) Rear Axle Seals
33) Wheel Cylinder
34) Calipers
35) Fuel Filter- Napa
36) Fuel Pumps (If Needed?)
37) Exhaust Manifold Gaskets- Shucks
38) Paint Valve Covers, Block, Oil Pan and Intake
40) Clean Engine
41) New 31x10.50x15 All Terrains
42)Clean and Polish Wheels
The list is long but not everything is maditory right away.
Stage 1:
-Regasket and Motor Install
-Fluid Changes
-RUNNING!!!
Stage 2:
-Road Worthy
Stage 3:
-Upgrades
Last edited by Tsoptich; Apr 1, 2012 at 02:11 AM. Reason: More Parts Bought And Items Checked Off
Old Mar 25, 2012 | 12:54 AM
Tsoptich's Avatar
Tsoptich
Well I finally got my motor mounts and hardware today, from JBG and planing on installing the gaskets and engine on Wednesday. Waiting for a chance to get a new (used) exhaust manifold from the JY, maybe next week. I had the radiator shop look hot tank my rad and it checked out. So that's a money saver there. I sold an extra transfer case I had out of my 78 f150 for $100, that should take care of my tune parts and a case of beer for an all night wrench feast. So there's the news.
Old Mar 25, 2012 | 02:32 AM
deljac's Avatar
deljac
cant forget the beer nothing goes together rite without that. lol
Old Mar 25, 2012 | 08:56 AM
BearFootCustom's Avatar
BearFootCustom
I love that style radio, once in awhile I put mine back in my truck just for a change of scenery
Old Mar 25, 2012 | 11:31 AM
Tsoptich's Avatar
Tsoptich
They still sell cassettes at the drug store in town. Might have to keep it. 👍
Old Mar 29, 2012 | 05:16 PM
Tsoptich's Avatar
Tsoptich
I recieved my exhaust manifold for the truck yesterday. went to the junk yard and they wanted $65 for one and I got it though Napa for $72 at least I didnt have to mess with pulling it. Also got a fuel filter so hopefully I will feel better and get on working on the truck.
Old Mar 29, 2012 | 05:36 PM
Diesel_Brad's Avatar
Diesel_Brad
I was gonna say, A USED MANIFOLD? What a waste of time and money
Old Mar 30, 2012 | 02:28 AM
TexasGuy001's Avatar
TexasGuy001
I'd say you got a stellar deal. I would pass on the hoop steps. They put alot of stress on the rockers.
Old Mar 30, 2012 | 09:20 PM
Tsoptich's Avatar
Tsoptich
I was going to get a used manifold for now, the reason being I was planing on some headers but I think I will keep the manifolds. As far as the hoops steps I am thinking about making a braket for them to attach to instead of the rocker.
Old Apr 11, 2012 | 10:09 PM
Tsoptich's Avatar
Tsoptich
Its been awhile since I posted. I finally got a chance to work on the truck and shot some pictures. Just about ready to get motor set in the truck. I got the valve covers resealed, the upper intake gasket installed, drivers side exhaust manifold on, exhaust manifold gaskets (might aswell do both since I had one off) motor mounts on, and front end and timing cover removed and cleaned up. I found the timing chain was a little lose and since I had it apart I ordered up a new one. Now for some pictures:
New Manifold, you can see the new motor mount
Excessive play
All cleaned up
I had to break the bracket because the double nut wouldnt losen up
Have to fix some vaccum lines
Thats all I have for now. I havent got a chance to work on the truck for a week or so. I got the timing chain, and I am looking for a pulley for the crank shaft.
Old May 25, 2012 | 10:33 PM
  #28
Tsoptich's Avatar
Tsoptich
Its been a while since my last up date. But I finally got the motor trany transfer case in the truck. I am about to fire it up for the first time. Its getting exciting. I scored a crankpulley for the 302 out of the junk yard for $10. I am hoping to throw a fuel gallons of fuel in each tank and seeing if we can get it to pop off, or figure out what the fuel issue was that the PO was talking about. Here is a picture for you all:
If all goes well then it will be coming home from the shop to finish putting the rig together. Need to install drive lines, clean it up and then the customizing begins.
Old May 25, 2012 | 10:47 PM
  #29
BigBlueOx's Avatar
BigBlueOx
Originally Posted by Tsoptich
That's a unique intake manifold. I've only seen that in the Ford service manual.
Old May 25, 2012 | 10:53 PM
  #30
Tsoptich's Avatar
Tsoptich
Thanks? If you want one there are 2 in the junkyard here. I hope its the right one.
