Home made traction bars question
Old Feb 24, 2012 | 07:49 PM
Crewcab Turbo's Avatar
Crewcab Turbo
Im looking for opinions and technical knowledge. I bought my truck with stacked blocks.We all know how safe that is. So I am making a set of 5 1/2" blocks with traction bars. Similar idea as OUO. I am trying to use stuff I have lying around to keep the price low. My question is, for the long bars, aproximatly 62" long. Would DOM 1 3/8" OD tubing with 1/4" wall thickness be strong enough? It seems to me that most of the force will be push pull. This tubeing seems to be plenty strong. I really don't know how strong it needs to be. Thank You!
Old Feb 24, 2012 | 08:21 PM
megawatt00's Avatar
megawatt00
That should be fine for strength, Your not running mega HP that would warrant anything bigger. Make sure to match the angle of the drive shaft when figuring the length of them
Old Feb 25, 2012 | 12:30 AM
kawcrasher's Avatar
kawcrasher
The tubing seems plenty strong for that. What I would concerned with is mounting it on the block. If your running a single bar, It seems that you would just be adding a pivot point for the axle to wrap on. It would also put alot of stress on the u bolts and centering pin. I've seen a D60 center section break lose and spin on the tubes with a SBF and 39.5's and low gears, so don't under estimate the amount of force involved when building brackets.
Old Feb 25, 2012 | 08:15 AM
Crewcab Turbo
I plan on two bars one on each side. I plan on attaching the bars to the block. The blocks are made from 3"x5"rectangle 1/4" wall DOM tubing with 3/8" plate for the block top and bottom. The u bolts are going through the bottom plate for extra strength. I also plan on making a gusset to the axle tube for even more strength. My friends wife's jeep spun the housing on a corporate 14 bolt running 39.5 boggers with 4.11 gears turbo 350 and a stock Chebby 350 motor. I do know there is lots of torque there. I don't beat on my truck and I only have 285 75 16 At tires so I would think I will not be spinning the housing. I hope!
Revolver-time
Jun 13, 2016 06:50 PM
Sous
121
Jun 13, 2016 04:39 PM
joeyd61
Mar 4, 2012 12:14 PM
RangerHaywood
Jun 29, 2010 03:34 PM
KubotaOrange76
Offroad & 4x4
Jul 1, 2005 02:57 AM
