Easy Trans Service Question
Old Feb 24, 2012 | 06:01 PM
anthony605's Avatar
anthony605
I am going to drop the trans pan and change the filter on my 2008 F150 4x4 STX 4.6 litre. How many quarts of trand fluid do I need to re-fill the trans. Im only dropping the pan. Thanks!!!
Old Feb 24, 2012 | 06:53 PM
Coskid's Avatar
Coskid
About 3 quarts but you should check it after refilling it to see if you need more. What i do is add two quarts check it and then add more as needed.
Old Feb 25, 2012 | 07:01 AM
anthony605's Avatar
anthony605
Thanks for your help!!!
Old Feb 25, 2012 | 07:06 AM
Coskid's Avatar
Coskid
No problem I just did this service about two weeks ago.
Old Feb 25, 2012 | 08:34 PM
sniswend's Avatar
sniswend
If you can afford it I would recommend buying a trans pan at the parts store that has a drain plug in it or at least put one in you stock pan. It makes a world of difference and it will make it easy if you want to keep the fluid fresh by draining and adding three quarts ever other oil change.
bcaughhorn
Nov 17, 2016 04:37 AM
emspjay
Dec 10, 2014 06:14 AM
TXBob
Jun 5, 2010 12:11 PM
BADAS03SVT
Nov 27, 2008 09:00 AM
Beaned
Aerostar
Feb 20, 2004 11:47 PM
