Poor Oil Pressure
Old Apr 24, 2003 | 09:18 PM
Monster 78 F-150 4X4's Avatar
Poor Oil Pressure
I have a 78 F-150 4X4 with the 351M. I bought truck about 1 month ago. When i replaced the exhaust valve on #3 i noticed the enging has a good lip at the top. The engine has 220,000 on it. It is all stock and I put an oil pressure gauge on and when the truck warms up it only has 10 to 12 psi. It will hit a little over 20 psi during accelerating. Also the other day when I drove it to school for the fist time and when i went to leave the pump stuck and nothing showed up on the gauge and the rods started nocking It ran for maybe 15 seconds i shut it off, checked the oil, then restarted it and i had its normal pressure. Im running 10w-40 with a can of restore in it. What do you think I should do???
Old Apr 24, 2003 | 10:39 PM
BentWheel's Avatar
BentWheel
Poor Oil Pressure
Get the engine rebuilt.
Old Apr 25, 2003 | 03:45 AM
macguyver's Avatar
macguyver
Poor Oil Pressure
Or drop in a (used?) 400. It depends on your budget. Sounds like she's just really tired. A rule of thumb is 10 psi of oil pressure for every 1000 RPM. You might try straight 30 or 40 weight oil to get you by. If you can find a decent used engine, that would be an option. If the replacement has a front sump oil pan, you can swap your pan (with your pickup tube, new oil pump etc.) onto it.
Just my 2¢
And welcome to FTE.
Greg
Old Apr 25, 2003 | 09:08 PM
Poor Oil Pressure
Thanks for your advice guys. In a about 2 months im going to drop in a 460 ive got lined up. I just gota wait till shcools out (about 4 weeks) then go back to making good money working full time then ill do it. Also this isnt an everyday truck so i can afford to have some down time.
Old Apr 25, 2003 | 10:40 PM
macguyver's Avatar
macguyver
Poor Oil Pressure
Put some 40 weight oil in it and enjoy.
Straight weight oil tends not to break down as much as multi-weight. And these 351M/400's will run almost forever with practically no oil pressure.
Old Apr 25, 2003 | 10:58 PM
BentWheel's Avatar
BentWheel
Poor Oil Pressure
40???? Before the rebuild I ran 90 weight for a while. Try 50 weight and ignore the gauge, tape over it if you have to.
Old Apr 26, 2003 | 10:02 PM
Poor Oil Pressure
So you guys think i should just run 50W oil. Also should i hold off with the engine swap and just lift 4" and put some 35" Mud Kings on it. Also the truck will rarly be offroaded hard.
Thanks
Old Apr 26, 2003 | 10:25 PM
BentWheel's Avatar
BentWheel
Poor Oil Pressure
Yep, 50 weight's fine for your engine.
I'd do the engine swap first.
IMO it's better to have a reliable drivetrain before anything else.
