lapping in valves
Old Apr 26, 2003 | 09:31 PM
dustinleavitt2000's Avatar
dustinleavitt2000
lapping in valves
I did a 3 angle valve grind on my valve seats and got seats pressed into the exhaust. My question is do I need to lap in my valves and how would I go about doing so.
Old Apr 26, 2003 | 10:07 PM
BentWheel's Avatar
BentWheel
lapping in valves
No you don't need to lap the valves however if you didn't get your valves ground have them ground at an angle that is one degree smaller than the seat angle i.e. a 45 degree seat and a 44 degree valve. FYI valve grinds are desireable even with brand new valves
Old Apr 26, 2003 | 10:34 PM
dustinleavitt2000
lapping in valves
I bought new valves and i am really unsure of what to do now. could someone give me a run down of how install the new valves?
Old Apr 27, 2003 | 02:33 PM
dustinleavitt2000
lapping in valves
I did a kind of hasty job on the 3 angle grind would lapping them help?
Old Apr 27, 2003 | 03:00 PM
shazam's Avatar
shazam
lapping in valves
OK if your really not sure I'd take it to a Machine shop and let them do it ... You have to make sure the angles are right and the installed spring height is right with the seat pressure....
Old Apr 27, 2003 | 03:16 PM
gregdatech's Avatar
gregdatech
lapping in valves
Lapping will do a finishing job on seating the valves. If the angles are way off etc, it wont help. It wouldnt be a bad idea to lap them just to make sure they will seal before you put it all together. Sometimes machine shops arent perfect, and its so simple and quick why not?
Old Apr 27, 2003 | 05:40 PM
dustinleavitt2000
lapping in valves
I just lapped in one valve, it appears that i made the single groove way too small because after lapping its bigger.
I installed it and filled the port with wd 40 and it doesnt appear to leak from the valve.
Is this a viable way of telling if I have a good seal or not?
Old Apr 27, 2003 | 06:27 PM
BentWheel's Avatar
BentWheel
lapping in valves
Sure lapping can help on a rare occasion but it's also a better way to screwing up a good valve job. To check the valves for sealing get some perusian blue, it comes in a tube and you coat the face of the valve with it and then smack it against the seat, if the seals are good their should be a line around the valve a few thousands in from the edge.
I agree with shazam thought, if your not real sure on how to do this stuff let someone else do it or learn how to do it before trying.
907steveb
Aftermarket Products
May 2, 2015 07:48 AM
broncoderek
Sep 7, 2014 02:35 PM
tiopet
Apr 4, 2013 09:20 PM
Aneyeforjunk
Oct 11, 2009 08:03 PM
