Re-gearing
Old Apr 2, 2012 | 02:20 PM
  #46
HeathJohnson's Avatar
HeathJohnson
Well I called them this morning... Ended up doing the whole order through bronco graveyard... They looked up the "Name Brand" part number for me, ended up being Yukon's...
Old Apr 3, 2012 | 03:05 PM
  #47
Rosson03's Avatar
Rosson03
a forgotful question
higher gears less rpms
lower gears higher roms
Old Apr 3, 2012 | 03:08 PM
  #48
Rosson03's Avatar
Rosson03
which is better for towing
and which is better for in town and out town driving!!! thanks!
Old Apr 3, 2012 | 03:11 PM
  #49
markland's Avatar
markland
Higher ratio better for towing, lower supposedly better on the highway.
I went from 3.73 to 4.30 in my V10 Excursion running 315's and picked up 1-2mpg in town, 2-3 towing my boat and highway mileage stayed around the same.
I went from 5-6 to 7-8 towing, 8-10 to around 10 average and get about 12-13 on the road.
Old Apr 3, 2012 | 03:14 PM
  #50
HeathJohnson
The Excursion is uses almost exclusively for towing and bad weather driving so I don't mind the higher RPMS when I am just using it for a run to town or something. Overall I'm hoping that the lower gears help my MPG too because the truck won't be working as hard to turn those oversized tires!
Old Apr 3, 2012 | 08:19 PM
  #51
ATV PRO #11's Avatar
ATV PRO #11
Originally Posted by X_Hemi_Guy
Are you guys that are running these gynormous tires doing anything to correct the speedo?...if not...the mpg's you are calculating will be way off regardless because the miles traveled per tank will be off due to the inaccurate speedo...a vicious cycle.
Now a re-gear does NOT affect the speedo because of where the speedo pick up sensor is located...but you would need a tuner to reprogram the PCM for tire size change...
Just thinking as I type.
Joe
Does this thing work at all?? I'm 4:88 with 42's and I'm 24 off. Confirmed on profesional speedo tester. Sorry if this is off topic
TRU-SPEED SENSOR CALIBRATOR, MOD. A
Old Apr 3, 2012 | 10:05 PM
  #52
EXv10's Avatar
EXv10
It's not really working harder to turn over big tires but getting close to the stock overall ratio is what's important. The spinning weight is actually just total truck weight and the slightly extra rolling resistance is the only drain on horsepower. You're not really putting out more horses to spin big wheels unless they were spinning free (off the ground) and even that would diminish as the max speed is attained.
Old Apr 4, 2012 | 07:37 AM
  #53
markland's Avatar
markland
My speedo is about 8% percent off so I just use my Scangauge II to correct my speedo as well as track my MPG, trans temp, etc. Works great and you can calibrate the unit for your setup. I used GPS to calibrate my MPH and seems to work very well.
Old Apr 4, 2012 | 08:44 AM
  #54
ComputerCowboy's Avatar
ComputerCowboy
Wink
I have one on my truck... I hope it works, IDK, I haven't had it out on the road yet.
Should get a chance to test it next week. Maybe even this weekend.
Old Sep 7, 2024 | 09:53 PM
  #55
BrittonN's Avatar
BrittonN
1st Gear
Hey brother, I live near you in ellijay ga. do you know of a reputable shop that can swap some gears on an excursion? Thank you for all your info btw very helpful!
Old Sep 8, 2024 | 01:15 AM
  #56
John in OkieLand's Avatar
John in OkieLand
long ways from Ellijay, GA
I just looked up where you are....
just a few minutes from my son in Dawsonville, GA
Smothers Supercars in Oologah, OK did my Excursion rear diff,
did it right, and a fair price.
http://www.smotherssupercars.com/
traildogg
Oct 20, 2015 10:13 AM
balfor
Modular V10 (6.8l)
Jan 7, 2008 09:47 PM
frankovsky
Oct 5, 2007 08:19 AM
paul
Modular V10 (6.8l)
May 31, 2007 01:55 PM
Crockett
Modular V10 (6.8l)
20
Mar 7, 2006 10:47 AM
