Intercooler pipes
Old Feb 23, 2012 | 03:09 PM
KonaGrown's Avatar
KonaGrown
Intercooler pipes
Just trying to piece together my intercooler set up and was wondering if the coupler bends in the pipe needed to be welded together, or would exhaust band clamps work if you go from od to id connections?
Old Feb 23, 2012 | 03:17 PM
mjonesjr's Avatar
mjonesjr
You need the piping to be as air tight as possible. Any openings, even small ones, will cause boost leak.
Old Feb 23, 2012 | 03:26 PM
strokin'_tatsch's Avatar
strokin'_tatsch
Weld them and be done with it.
Old Feb 23, 2012 | 03:34 PM
KonaGrown's Avatar
KonaGrown
Do it right... do it once. Time to pull out the old welder, I'm a little rusty.
Old Feb 23, 2012 | 04:48 PM
fordpride's Avatar
fordpride
Do you need SD pipes? If so PM me I'll make you a deal on a set
Old Feb 23, 2012 | 04:51 PM
MHammer21's Avatar
MHammer21
how much work do the SD Pipes need to make them work? Is it easier to just make your own if you had a mandrel and decent welding skills?
Old Feb 23, 2012 | 05:47 PM
richdawg's Avatar
richdawg
Limited Edition
Anyone know what Limited Edition is/means, did they forget something or do I have something special, other than this name plate it's just a XLT as far as I know.
Old Feb 23, 2012 | 05:50 PM
richdawg's Avatar
richdawg
Sorry I thought I was starting new thread.
Old Feb 23, 2012 | 06:22 PM
strokin'_tatsch
The SD pipes arent too hard to make work, just gotta add a few bends. It wouldn't be hard to order in some mandrel bends and fab up a set of pipes, but it would be more time consuming than starting with SD pipes.
Old Feb 23, 2012 | 08:41 PM
KonaGrown's Avatar
KonaGrown
I didn't know the SD pipes would work. Looks like I don't have to humiliate myself welding a set together after all.
Old Feb 23, 2012 | 09:41 PM
oldbird1965's Avatar
oldbird1965
I made the SD pipes work but got laughed off of another forum about it. No leaks and been working for five-six years.
Old Feb 23, 2012 | 11:02 PM
KonaGrown's Avatar
KonaGrown
What did you have to do to make them work? What part of the SD pipes did you have to modify?
Old Feb 23, 2012 | 11:28 PM
oldbird1965
I used two pieces of 2 1/2" in length exhaust pipe, welded a welding rod around the ends to hold the boots. I then doubled booted them to the spider. Jerry rig? It works, no leaks and never blows off. I don't care about pretty, I care if it works. (notice I'm depending myself before this is even posted, LOL)
Old Feb 23, 2012 | 11:44 PM
chicagodragon's Avatar
chicagodragon
I thought you used a pringles can to make the connection. Lol! Hey glenn
Old Feb 24, 2012 | 12:09 AM
oldbird1965
Hey George, hmmm, a pringle's can does have a lip at each end. Never thought of that, LOL
