running boards???
Old Feb 22, 2012 | 08:13 PM
Layed Out 100's Avatar
Layed Out 100
running boards???
Is there any big difference between the smooth style and the original style boards?
I think I would like to have the smooth style type but I'm not sure, Only thing I could imagine being a downfall of the smooth ones would be scratches???
Old Feb 22, 2012 | 09:04 PM
51PanelMan's Avatar
51PanelMan
And more prone to slipping off when the board is wet or greasy.
Old Feb 23, 2012 | 09:16 AM
GreatNorthWoods's Avatar
GreatNorthWoods
I got the ribbed boards because they looked more original. The smooth ones look good on a highly modified truck but if your truck will be a restomod then I'd stick with the ribbed boards....
Old Feb 23, 2012 | 12:01 PM
Jag Red 54's Avatar
Jag Red 54
What are you going to do with the truck? Do you have any small kids that will climb on them? Running boards are an open invitation to small kids to climb up so that can see in the bed. So whether at a show or at home, beware the smooth RBs. If there are going to be little kids having access to your truck, then the ribbed RBs with the attached decorative strips is the way to go. They are real paint savers! Jag
Old Feb 23, 2012 | 08:28 PM
Layed Out 100
Thanks guys thats just what I was needing to hear. Think I will be going with the original style. Even though my truck will be highly modified I do have two kids, a five year old and a one year old.
Old Feb 23, 2012 | 08:30 PM
ZOOT's Avatar
ZOOT
Go for the ribbed boards. Just my 2c
Old Feb 23, 2012 | 08:34 PM
FlatoutKrazy's Avatar
FlatoutKrazy
for HER pleasure
Old Feb 23, 2012 | 08:53 PM
Layed Out 100
Originally Posted by FlatoutKrazy
for HER pleasure
LMAO I was wanting to say the same thing!
How is yours coming?
Layed Out 100
Your truck that is
Old Feb 23, 2012 | 09:04 PM
FlatoutKrazy
Lol, its not right now, threw my back out last week at work missed 5 days, just gettin back to movin!!! gonna be slow for a while. just looking into the s10 tailshaft swap on the mustang t5 tranny right now,. Think im gonna do that... moves the shifter forward about 7/8 inches. aaaand lookin for a good deal on a 8.8 rear end scouring craigslist every day...
Old Feb 23, 2012 | 09:11 PM
Layed Out 100
I have noticed 8.8 show up around here about once a week on craigslist. One will show up for you soon.
Have you seen the thread of the 49 laying boards just posted?......good thread! seams like it was slow around here for the last week or so then today there are about four new people with good builds.
Old Feb 26, 2012 | 11:36 PM
ike55's Avatar
ike55
I picked up an Explorer rear end with disc brakes and sway bar at pick and pull for about $200 a couple weeks ago. I called around different yards and they go for about $300 or more at other yards. But, they are readily available.
Old Feb 27, 2012 | 12:16 PM
Samsn4's Avatar
Samsn4
does the explorer axle fit well ? Any mods ? I've seen alot using the Dana 40 or 60 i believe, from the '76 F250.
Old Feb 27, 2012 | 09:52 PM
ike55's Avatar
ike55
The Explorer is an 8.8 and is the correct width. Mine was a '96 with disc brakes. There were a couple of '95's that had drum brakes. You will need to relocate the spring perches and fab sway bar and upper shock mounts.
Old Feb 27, 2012 | 10:35 PM
ben73058's Avatar
ben73058
Hey Adam,
I'd vote for ribbed running boards - coated mine with a bedliner type material to make it even less slippery & I didn't want to worry about paint.
I think $300 is a bit steep for an 8.8. We used one for our 1950 F1 - it came from a 2001 Explorer with 3.73 gears & nice disc brakes ($125).
It's not totally plug & play as mentioned above by Ike you have to relocate a few things like the shock mounts & spring perches. A few other things to note - it will change your lug pattern so you will need new wheels & you will probably want to match them up front so you can carry just one spare. Also we found "the rake" to be a little too high with our mustang II front end so we had the Explorer springs flipped to lower it a little. Our 1950 F1 originally came with like 8 springs in the stock format - the 8.8 from the Explorer comes with a 3 spring set up - not sure it can carry the same load out back if that matters to you.
Pics of our running boards below with bedliner & a pic of the 8.8 rear axle.
It doesn't look like much but it cleans up just fine. We also picked up the emergency brake off the Explorer as well.
Good luck over there.
Ben in Austin
pbsdaddy
21
May 8, 2021 09:08 AM
100550dvr
25
May 8, 2019 08:13 AM
Buck Fifty
2015 - 2020 F150
Apr 17, 2016 04:12 PM
MPH Racing
Jan 10, 2011 02:56 PM
stephen.osborne1
2009 - 2014 F150
Oct 27, 2010 01:57 AM
