Fuel tank update....help
Old Feb 22, 2012 | 03:47 PM
2006powerstroke90's Avatar
2006powerstroke90
Well, from what I was told, the truck had a dead pedal...well that was wrong.
I got to the truck this morning, started it and it had a HORRBILE fuel knock. Towed it back to the shop, pulled the fuel filters and I was shocked. This is what I found.
So, I checked F.P. w/ a mechanical gauge and got like 27PSI or so. DEF not enough pressure.
Its on a F-450 rack body, metal tank....So basically what I need to know is....is there any kind of protective liner Ford put inside the tank that could be flaking off and clogging everything up now?
I have about 25GAL of fuel in the tank, which I will have to drain then drop the tank, pull off all the fuel lines blow them out and go from there.
I can't see what else would be causing this? Ill just start from the source and work my way up.
Thanks.
Old Feb 22, 2012 | 04:00 PM
Ian123's Avatar
Ian123
The metal tanks had a problem with rusting. I think they were only used on cab and chassis models.
Old Feb 22, 2012 | 05:56 PM
cheezit's Avatar
cheezit
yes they are lined with a grey liner. that tank is just over $1200. I would suggest finding a shop that will reline it.
also I would suggest flushing all the line, 8 new injecotrs, new frame mount pump, filters and a regulator ....
to start
Old Feb 22, 2012 | 06:41 PM
2006powerstroke90
to start
Glad its not my dime!
So that has to be the gray liner flakes im seeing. I have no problem doing the work, the truck is a 2WD which also makes it easier.
So you think it took out all of the injectors with it?
Old Feb 22, 2012 | 06:43 PM
cheezit's Avatar
cheezit
it will at some point soon. But hey Ive been wrong before. this will be the guy that has one dead bank in a few months and no one will know why.
Old Feb 22, 2012 | 06:51 PM
2006powerstroke90
Welp, if I have to I will insit on new injectors.
The thing is, I try to explain them that if these injectors get starved for fuel, then they will more than likely fail.
We USED to take our trucks to another shop, so really its my word against theirs.
We have found someone to reline the fuel tank, so I guess I will start there and see what the company wants to spend on the truck.
This truck goes everywhere, out of state, miles and miles away, so it would honestly make sense to do it right once.
I will drop the tank and post up more pictures.
Old Feb 22, 2012 | 06:53 PM
cheezit's Avatar
cheezit
man if you have to make a note on the ticket, remove and clean the frame mount pump and reinstall the tank.
You cant force people to fix stuff the right way if they dont want to.
Old Feb 22, 2012 | 06:56 PM
2006powerstroke90
You're absolutely correct.
Then, when the truck goes down again due to bad/faulty injectors who's the first person to blame...ME...Which I don't like to much.
Anyways, thanks for your help! I will post up more info as I go along.
Old Feb 23, 2012 | 04:28 PM
2006powerstroke90
Okay, well I got the tank off of the truck man, getting it off was EASY even with 30GAL of fuel in it. Literally didn't spill a drop.
Slid the tank out from under the truck, and it was FULL of flakes/rust
Drained all the fuel out of the tank, and I was almost getting spoon fulls of sediment.
Got the tank to the place thats going to line it again, and its a 2.5-3WK wait! oh well.
So I got the fuel lines off and all blown out, the fuel pump off the frame sitting on my bench to finish it up tomorrow. By the looks of the secondary filter that was in it, the flakes really didn't seem to make it up that far, but i KNOW lack of fuel pressure will destroy the injectors, ill keep my fingers crossed for the company that the injectors will be okay.
Anyways, thanks for the help/info.
Ill be working on a 05 GMC Savana for the next few days...
Old Mar 11, 2012 | 09:35 AM
2006powerstroke90
Well, I had the tank lined, and reinstalled it, blew out all the lines, cleaned the fuel pump(main filter housing)
Put 15gal of fresh diesel, new ford filters....
Truck started almost instantly with a few key cycles, it idled for 2 hours hoping it would clear up, I went outside, truck was running GREAT when to take it around the block, and it died almost half way, limped it back....
Cleaned out filters, restarted.....ran good for a few minutes....then same problem died....
If I cycle the key about 5 times....it will run good, then start with the fuel knock and eventually stall out....
I can do the key cycles and it will be fine....then knock...I can do that all day long.
Any ideas?
Old Mar 11, 2012 | 09:40 AM
dlibson's Avatar
dlibson
Check your pressure again?
Old Mar 11, 2012 | 09:42 AM
2006powerstroke90
Its about 53/54 PSI
I think its injector time..
Wish I had an A.E.
Old Mar 11, 2012 | 09:50 AM
dlibson's Avatar
dlibson
I wonder how much junk is sitting in the injectors still? Probably is injector time yes.
But you could have pump issues too, check your pressure when it dies. It could be the pump is getting warm, and then stopping...
Old Mar 11, 2012 | 04:24 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Seems I had the same problem...
My pre-pump filter caught it all before it even made it to be pump. Had to drain the filter twice, but it seems like I got it all.
caravaggio2000
Sep 17, 2018 04:48 PM
hotweekend
25
Mar 10, 2013 04:49 PM
bpounds
Jul 9, 2012 10:08 PM
Björn
Jan 12, 2011 02:40 AM
