What shocks for V-Code springs
Old Feb 22, 2012 | 02:51 PM
ToyhaulinEX's Avatar
ToyhaulinEX
Hello all,
New member here. I just put on V-Code front springs. I purchased Bilstein front shocks also. I ordered the shocks for a 2000 F350 TD 4X4 dually because the local Ford dealer told me that was an application for the springs. The shocks needed to be a little compressed to fit in at full suspension droop. Now that the spring swap is completed, I noticed the shocks are quite a bit compressed with the full weight of the EX sitting on them.
Is this normal or "ok"?
Should I have just purchased "stock" replacement shocks? I was worried the stock shocks wouldnt allow enough travel for the little bit the EX gets off the road...
I drove the truck out of the garage, and already noticed it steered easier and was better just going through our parking lot.
Old Feb 23, 2012 | 12:17 AM
hasteranger's Avatar
hasteranger
Most people who just swap the springs put stock excursion springs back on. the F-250 is normally what people step up to if they change them out. I've been told it doesn't really matter, that the stock ones have enough travel, while the F-250 ones are essentially what those springs came with stock. The f-350 ones are probably the same as the F-250 ones. as long as you have more travel in your shock than you do distance from spring to bumpstop you are fine. If you don't, you need to change something.
Old Feb 23, 2012 | 09:50 AM
petes4x4's Avatar
petes4x4
I looked up shocks for both the excursion and the f250 and the part numbers were the same. I am running excursion shocks with v code springs with no problems.
Old Feb 23, 2012 | 04:38 PM
hasteranger
the part numbers are different for some on summit, I guess it depends what brand maybe.
KSun90
Oct 13, 2013 07:55 PM
hink10
Sep 28, 2012 12:44 PM
SurpriseF350Sport
Dec 30, 2010 01:38 PM
turnrjr
Mar 16, 2010 08:59 PM
aklim
Mar 25, 2007 09:36 AM
