Still loosing prime!
Old Feb 22, 2012 | 04:01 AM
IDI guy's Avatar
IDI guy
Ok I am at my wits end! My 88 7.3 N/A was having cold start issues so I changed (sence I drove it last): 2new batterys, new passenger side ground cable 00 custom(nice), lift pump, return lines viton o rings, all olives, cleaned all terminals and treated with dielectric grease, new one piece fuel filter/water seperator, new starter. Ok it still will lose prime after only sitting for 10 min I have no fuel leaks. After cranking on it to start it makes a huge puff of white smoke and runs ruff for a few seconds then smothes out and stops smoking. My thinking is the fuel heater o rings in the filter head, or the soft return line in the rear of the engine other than that I don't know . Any ideas guys?
Old Feb 22, 2012 | 06:45 AM
farmnfly's Avatar
farmnfly
My friends similar problem was a rust hole at the elbow on the gas tank (sending unit) or youcould install an electric fuel pump, search the post there are several wasyto do it
Old Feb 22, 2012 | 08:31 AM
therifleman556's Avatar
therifleman556
A rusty sending unit could do it. Also, the rubber hoses run into metal lines inside the frame; mine were real nasty and caused rough starts and part throttle surging.
Old Feb 22, 2012 | 09:40 AM
IDI guy's Avatar
IDI guy
Also I think it is worth mentioning I took off the electric lift pump and replaced the old lift pump with a new one. I don't think it is the tank because it happens with eithr tank, maybe the tank 1selector unit I haven't checked there yet. There isn't any steel line it has this hard plastic fuel hose that runs back to the selector unit I think I will replace that with soft fuel hose next. Then maybe a sending unit off my 92 that only has one tank and see if that helps.
Old Feb 22, 2012 | 12:12 PM
therifleman556
Double check the lines going from the drivers side frame rail to the lift pump. It should be a steel line that runs under the front crossmember. It shouldnt be rubber or plastic the whole way, at least not unless someone changed it already.
Old Feb 22, 2012 | 12:27 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
grab yourself some fuel hose and hook your lift pump up to a jug of diesel.start the truck,and let it suck up some fresh fuel.now shut her down and see if she looses prime or holds.if she holds,then your air leak is before the lift pump(rusted fuel lines,mainly around the holding clips,fuel selector valve,tank pickups,etc.) if she still looses prime,then your air leak is after the lift pump (engine side/fuel filter,o-rings,heater,American valve,return lines etc.)
Old Feb 22, 2012 | 02:24 PM
IDI guy's Avatar
IDI guy
Great idea!
Pigpendirtface1021
31
Nov 30, 2018 12:17 PM
nolszewski
May 7, 2018 09:33 PM
jblueep
18
Jun 14, 2016 05:01 PM
shameless
Mar 22, 2009 05:59 PM
edneslo
1947 and Older Ford Trucks
Jun 2, 2005 09:38 AM
