Sponsored by: Auxito
P0402 code
Old Feb 21, 2012 | 09:47 PM
bbsitum's Avatar
bbsitum
P0402 code
"Check engine" is on at my F250 LD 99. I pickup code P0402 ( Exhaust Gas Recirculation Flow Excessive Detected ). I have this problem like 6 month. I can fill rough idle when is car at stop. First time when code P0402 show up and I felt rough idle (before 6 month) I replaced DPFE sensor "at blind". But it didn't solve problem. What else can be? EGR valve or EGR Valve Vacuum Regulator Solenoid. As I understand EGR valve at my truck is stuck open all times.
Old Feb 21, 2012 | 11:00 PM
Bluegrass 7's Avatar
Bluegrass 7
Remove the rubber hose attached to the EGR valve with the motor at idle.
Do you feel vacuum on your finger if you block the hose?
Does the engine smooth out with the hose off the EGR valve?
Let us know what you see and we will go from there..
Old Feb 22, 2012 | 10:02 AM
Longdistancetrucker's Avatar
Longdistancetrucker
Old Feb 22, 2012 | 10:09 AM
Longdistancetrucker
Sorry, it's alot of images for the diagnosis so it will take me a few posts....
Old Feb 23, 2012 | 11:26 AM
Bluegrass 7
Hey LD TRUCK, images are nice but none have anything to do with EGR.
Old Feb 23, 2012 | 11:53 AM
Longdistancetrucker
Thoose are not the origional images that I posted. I'm unsure why the images changed.....
Old Mar 29, 2012 | 07:02 PM
bbsitum's Avatar
bbsitum
OK I replaced DPFE sensor and EGR solenoid. No solution. It must be stocked EGR valve and I want clean it. But I can't open flare nut what is at EGR tube. I tried with 26 mm open end wrench that I can slide on but can't turn on, just it round corner. I need 26 mm FLARE NUT WRENCH with usual 15 degree offset. Where I can find it? It is not for sure 1" size as I can't put that size at nut.
smallello
May 21, 2015 06:30 PM
76f350spercamprspeal
S. California Chapter
Sep 10, 2010 01:52 AM
1_BIGMOFO
May 20, 2010 10:56 AM
Talyn
Michigan Chapter
29
Jul 29, 2009 08:59 PM
Surge08
Delaware Chapter
Sep 22, 2008 03:29 PM
