need some help
Old 02-21-2012, 05:42 PM
jdshoops's Avatar
jdshoops
jdshoops is offline
need some help
I'm having a hard time finding rear brake shoes for a 50 F-3.
I found one place that carries them and they are outragous. I'm keeping my fingers crossed that there are some other places out there that carry these big shoes. It doesn't help that I don't have a core either.
Thanks for the help!
Old 02-21-2012, 08:11 PM
51PanelMan's Avatar
51PanelMan
51PanelMan is offline
Have you tried JobLot Automotive in New York? They seem to carry the larger truck stuff.
Old 02-21-2012, 09:31 PM
tinman52's Avatar
tinman52
tinman52 is offline
Welder User
You may have to send them off to have them relined....contact a big truck repair shop in your area and see who they use.
Old 02-21-2012, 09:33 PM
denverslim's Avatar
denverslim
denverslim is offline
Joblot was the best I found too. I had to get a set of drums for my F-2. The other places (that had them) thought they were gold...slim
Old 02-21-2012, 09:47 PM
bobj49f2's Avatar
bobj49f2
bobj49f2 is offline
Received 2,104 Likes on 819 Posts
F-3 rear drums are not the same as the F-2, the F-3 drums are larger along with the shoes. Do search of this board and you find a lot of discussions about them. The prevailing thought is to swap in a newer, pre-'73 F-250 rear end. This allows you to be able to find parts and wheels that will fit over the rear drums easier.
Having the shoes relined is about your only option, figure that'll cost between $15-20 each. I just had a set done for a '37 Buick locally and it cost $60 for the four shoes on the back axle. Before doing this get your drums checked first, there isn't a lot of tolerance from stock allow to turn them down.
Old 02-21-2012, 09:52 PM
jmadsen's Avatar
jmadsen
jmadsen is offline
I dont have any shoes, but do have some good drums (almost new) from a 51 f-3 if anyone needs them. they are in the classifieds here.
Old 02-21-2012, 10:45 PM
51PanelMan's Avatar
51PanelMan
He doesn't have the old brake shoes to send in for relining.
Old 02-21-2012, 10:53 PM
jmadsen's Avatar
jmadsen
jmadsen is offline
You have the 14" rear drums? just been thinking of where some might be.
Old 02-22-2012, 08:44 AM
bobj49f2's Avatar
bobj49f2
bobj49f2 is offline
I didn't catch that for some reason. He could still search the posts pertaining to the F-3 rear axles and if he still wants to keep the F-3 set up he could try contacting some of the guy that might have done the swap, maybe they still have their F-3 parts. I've had a couple of F-3 and scrapped the rear axles without any consideration because there's no demand for them. He could also find a F-2 axle somewhere, I know they're laying around from all of the guys who have pulled them out to swap in 1/2 ton axles.
Irondragon did a swap some time ago but he still might have his F-3 parts, he was in western MI.
Old 02-22-2012, 09:51 AM
truckdog62563's Avatar
truckdog62563
truckdog62563 is offline
Marmon-Herrington Man
I scrapped a 14" drum axle a few months ago, and kick myself because I just hauled home the '50 F-3 M-H. Never fails, as soon as you think you don't need something, you do. Stu
Old 02-22-2012, 10:05 AM
jmadsen's Avatar
jmadsen
jmadsen is offline
There was a guy here recently selling 2 48-50 trucks f-2 and f3 both had 14" rear drums iirc? i contemplated buying them both but didnt. maybe he still has them?
Old 02-22-2012, 12:59 PM
Jeff and Nicolle's Avatar
Jeff and Nicolle
Jeff and Nicolle is offline
I just tore my '49 F3 Timken split axle apart.. I sold the carrier and the axles. I still have the axle housing, and drums, I would assume that the brake shoes are still inside the drums..I never had them apart and who knows what the previous owner has done, but I will check it out. I can't do it tonight, but maybe tomorrow night. Let me know if that would help.
I'll take 2 dollars for the parts and $600 for the labor.
Ok just kidding....
I was going to remove the ring gear from the carrier, but they are riveted on? no bolts.
Old 02-22-2012, 04:46 PM
jdshoops's Avatar
jdshoops
jdshoops is offline
thanks guys. I would like to swap the rear axle (someday down the road). Gota have a project next winter to do right. Mainly trying to get the truck on the road and still have a big list of things to get and do. Would like to find a set of rear shoes so i can have them relined. thanks again
Old 02-22-2012, 05:27 PM
Jeff and Nicolle
I will get them drums off and see what we got.
Old 02-23-2012, 10:34 PM
Jeff and Nicolle
Pictures of my brake shoes and the carrier(just for curiosity)
Quick Reply: need some help
