clutch problem
Old Feb 21, 2012 | 04:44 PM
oneshot4570's Avatar
oneshot4570
clutch problem
have 93 f350 4x4, had clutch assembly changed, (everything new) now the clutch engages about 1-2 inches from floor, took truck to dealer and tech said that, is normal, before having clutch assembly changed clutch was releasing about 2 inches from top. when clutch was changed we also changed passenger side motor mount, thanks for any help
Old Feb 21, 2012 | 05:21 PM
85e150's Avatar
85e150
With the clutch on the floor, does it go into gear easy when you are stopped and the engine running? Does is shift easily?
If so, you're good.
Any noises while idling in neutral? Any noises under power in any gear?
If nothing other than 'normal', you're good.
Old Feb 22, 2012 | 04:44 AM
oneshot4570
thanks, and yes it does go in gear easily, no grinding, however in neutral with engine running you can hear the TO bearing making a little noise, and thanks for reply again
Old Feb 22, 2012 | 04:51 AM
oneshot4570
thanks 85e150six4mtod, with clutch on the floor engine running it shifts normal (no grinding), throw out bearing makes a little noise that goes away when clutch is depressed
Old Feb 22, 2012 | 04:53 AM
Lazy K's Avatar
Lazy K
maybe still some air in the hydraulic system. I would drive it for a few days (rough roads if possible) and see if the pedal improves.
Old Feb 26, 2012 | 10:48 AM
jeff mc D's Avatar
jeff mc D
Cool verry hard to shift
My 96 bronco will not shift with ease, i have to start it in Reverse some times. I can't have my foot on the gas or breaks at all???
Aj Cook
Nov 8, 2017 09:03 AM
culterconverger
Oct 30, 2012 10:36 AM
Mishka0204
Feb 19, 2011 09:49 AM
Texas Outlaw
Nov 13, 2006 04:43 PM
agryphon
1983 - 2012 Ranger & B-Series
Jan 5, 2006 11:17 PM
