Sponsored by: Real Truck
Torqueshift poping?
Old Feb 21, 2012 | 12:10 PM
Madbasser's Avatar
Madbasser
Torqueshift poping?
Ok so i have been experiencing the popping sound when i take off and when i hit the breaks at a stop as the truck slows down but not completely stopped yet. Also some times when putting it in reverse. I started with all the normal stuff, checked the wheel bearings and replaced the ones o thought were bad, no fix. Then i replaced all three u joints and greased the slip yoke, no fix. Checked the break pins make sure they are all free, no fix. Make sure the suspension components were not worn and tight, all look good. No lose bolts that i can see or feel.
So yesterday i picked up the rear of the truck and had my wife jump in and start the truck. Thinking it nay be the rear-end.
I have her put it in gear and let the wheels spin for a bit then hit the breaks slowly. The pop is now more prominent. no matter if she pushes the breaks slow or fast it still pops.
It does not look like its coming from the Diff. There is no humm from the diff and the shafts have only about a 1/8 to 1/16th slop before engaged.
As i looked closer i observed the trans slowing down and just before a full stop it looked like it slipped and caught up a again. Is this normal.
This seems to be were my pop is coming from.
I have not pulled any trans codes and the tow/haul light does not blink.
So could it be the output shaft is stripped or a bad trans solenoid, or maybe even the torque converter?
I think its well into first gear when it does it, so i don't think its a 1-2 down shift, could it possibly be a torque converter lockout thing?
Oh sorry the truck is a 06' 5.4 SRW 150K. New to me.
Thanks for the help again guys.
I did change the tranny oil in the pan and changed the filter a few weeks ago, but still no fix.
Old Feb 23, 2012 | 11:19 PM
Madbasser's Avatar
Madbasser
No opinions??
Old Feb 24, 2012 | 08:25 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I don't have one. That's why I didn't reply. I'm terrible at diagnosing noises that I can't hear.
Farmin250
Mar 24, 2015 01:40 PM
LMPLLC
104
Jan 7, 2014 05:31 PM
gregghendrix
2004 - 2008 F150
Sep 19, 2012 07:38 PM
JOHN2001
May 31, 2011 04:15 PM
Waynenap
30
Apr 30, 2010 08:30 PM
