Texas Chapter Join Chapter, Leader: LibTimothy
MODs
Old Feb 21, 2012 | 10:55 AM
lee_faust2008's Avatar
lee_faust2008
MODs
im a service member... currently deployed and have had the chance to save up some money looking to get home and MOD out my truck..... i drive a 2006 F250 4x4 Crew Cab Lariat....
this is a list of all the Mod i plan on doing once im state side:
PERFORMANCE
HPOP upgrade
update blue spring
upgrade oil dummy plugs and stand pipes
scangauge 2
4-gauge pillar with EGT, oil temp, FP, and ECT
accessory fuse block
ARP head studs
EGR delete kit
AEM brute force HD air intake
SCT SF3 tuner
Diamond eye 4" turbo back exhaust
BD top speed eliminator
COSMETIC
3" rough country suspension lift
35x12.5x17 OR tucking 37x12.5x17
Dick Cepek Torque wheels 17"
possible regear to 4.10's or 4.30's
N-Fab pre-runner light bar (black) with 2 KC 130 long range lights
6" exhaust tips (black)
Aries tail light gaurds (black)
billet fuel door (black)
Eautolight LED projector halo head lights (black)
Spyder altezza tail lights (black)
Bully LED 3rd brake light (smoke)
driver and passenger mirrors
Go Rhino dominator 2 step bars (black)
mess front grille shell (black)
LED super duty door sills
LED bed rail lights
Go Rhino Lightning bed bar with 4 KC 130 watt long range lights
herculine the bed and the lower part of truck exterior making it 2-tone white/black
and OF COURSE the TEXAS LONGHORN black and chrome hitch cover
LET ME KNOW WHAT YOU THINK!!!! if theres anything im missing please let me know thanks for reading
Old Feb 21, 2012 | 11:10 AM
DRRXR's Avatar
DRRXR
Thumbs up
PERFORMANCE
HPOP upgrade
update blue spring
scangauge 2
ARP head studs
EGR delete kit
SCT SF3 tuner
COSMETIC
LED bed rail lights
What about copying your post and then posting that here---
6.0L Power Stroke Diesel - Ford Truck Enthusiasts Forums
Old Feb 21, 2012 | 11:20 AM
texans's Avatar
texans
PERFORMANCE
HPOP upgrade - not sure what an upgraded high pressure oil pump is (never heard of one), but the stock HPOP's on the 06's have very few to no failures. I would save your money on this one
update blue spring - good investment
upgrade oil dummy plugs and stand pipes - very good idea
scangauge 2 - another good idea
4-gauge pillar with EGT, oil temp, FP, and ECT - like I said on your post on the 6.0 forum, if your getting the SGII, I would replace the EOT, and ECT gauges with LPO, and an amp meter. You will have EOT and ECT on the SGII anyways. But you can't get the LPO or amps off of it.
accessory fuse block - ???
ARP head studs - good idea
EGR delete kit - not needed, what I recomend is keeping the EGR system intact, and if (yes if not when) your cooler fails, replace it with a bullet proof diesel one. They have very few to no failures. for $350 you could just put in a BPD one while doing the head studs.
AEM brute force HD air intake - stay away from this one. The stock air intake is the best thing on the market. It will flow as much or more air than any thing out there (at max HP and torque ranges that is), and filter way way more dirt to boot. Plus AM air intakes are known to cause problems such as dusting turbos.
SCT SF3 tuner - very good tuner, be sure to get custom tunes from either Eric at innovative diesel, or Matt at gearheadautomotive
Diamond eye 4" turbo back exhaust - good investment
BD top speed eliminator - won't need this with a tuner, it will already remove the limiter
COSMETIC
LED bed rail lights
My answers are in red above.
Thanks for your service. I was in the Army myself. Spent 04-05 in IRAQ.
If you want me to elaborate on any of those just let me.
Old Feb 21, 2012 | 12:04 PM
lee_faust2008
already posted it in the 6.0 forum....thanks for the gauge suggestions..... and the heads up on the air intake!!! i was just thinking for better fuel and power i should upgrade the air intake??
Old Feb 21, 2012 | 12:08 PM
texans's Avatar
texans
Yes sir, No problem. You won't get any power or MPG gain with an intake on a 6.0.
Old Feb 21, 2012 | 12:16 PM
lee_faust2008
so theres no benefit from getting a different air intake system?? not even a cold air or ram air system?
Old Feb 21, 2012 | 12:21 PM
texans's Avatar
texans
No sir. No real benefits, other than bling factor. Unless you want to chance turbo dusting.
Old Feb 21, 2012 | 12:22 PM
lee_faust2008
and can someone explain to me the purpose of the EGR and the benefits of the EGR delete? if there are any?
lee_faust2008
thanks for the intake info
Old Feb 21, 2012 | 12:24 PM
lee_faust2008
LPO= low pressure oil?? = oil pressure gauge correct?
Old Feb 21, 2012 | 12:41 PM
texans's Avatar
texans
The EGR system in a nut shell recylces part of the exhaust back into the motor to be re-burned to help lower NOX emissions. There are no benifits to deleting the egr system (at least as far as HP/MPG). The reason people delete the EGR cooler is to eliminate the posibility of failure. There have been lots of failure, but it's not all in all a bad system. There are lots of guys running around with 300k + miles and still have the stock cooler, that has never been replaced. So I recomend keeping the EGR cooler, or replacing it with the BPD unit that is a much better design. I have installed them for customers, and I really don't see them failing with the way they are built. Not to mention that tampering with emission equipment is illeagl.
Yes LPO is low pressure oil. and your right i'm talking about getting a low pressure oil pressure gauge.
Old Feb 21, 2012 | 12:47 PM
lee_faust2008
ok thanks.... i just always thought it had a pwer fuel benefit to deleting it but hey i guess i learned something new today thank you guys for the help and info
Old Feb 22, 2012 | 02:30 PM
Snuggyworm's Avatar
Snuggyworm
lee_faust2008, thanks for ur service. i spent 5 years in the army after graduating from westpoint academy. it was the only way out for me after i looked at the final bill for my tuition. i almost fainted.
thanks as well to scotty (texans) who has served our country as well. u guys make me feel proud to have done likewise.
SCFlareside
36
Dec 17, 2016 05:11 PM
Tylus
May 13, 2013 03:37 AM
TOMYO61
2009 - 2014 F150
Dec 15, 2012 06:24 PM
lee_faust2008
Feb 21, 2012 06:14 PM
lee_faust2008
Feb 21, 2012 12:18 PM
