Glowshift Gauges Install Help????
Old Feb 21, 2012 | 08:15 AM
f350rebel7788's Avatar
f350rebel7788
Disabled USMC Veteran
So I just got my gauges (35PSI boost, 1500* EGT, 100PSI Fuel) from Glowshift (I wanted ISSPro, but money was a big factor this time) and they don't really have the most explanatory instructions... I got the 3 gauge wiring kit as well, so that makes it easier to keep all the wires nice and neat, but i'm not really sure where to wire them all to and what not... so my question is if someone who has done the install could provide a write-up or at least let me know what they chose for power sources. I'm trying to figure out where to set up my fuel pressure sensor as well. Thanks in advance!
Old Feb 21, 2012 | 08:29 AM
fordpride's Avatar
fordpride
One wire goes to 12v always hot. One to key on hot. One to sending unit. One to ground
Old Feb 21, 2012 | 08:33 AM
fordpride's Avatar
fordpride
Maybe this will help better
GlowShift Technical Support - Installing Glowshift Gauges
Old Feb 21, 2012 | 08:39 AM
f350rebel7788
yeah, that's about all the instructions said too... but what i'm wondering is did you splice them in to the fuse box? is there an easy way to figure out what's always hot/only key hot? where's the best place to put the EGT sensor? where do i put the fuel pressure sensor?
Old Feb 21, 2012 | 09:18 AM
fordpride's Avatar
fordpride
Get these and tap into the fuse box
Motormite/Blade fuse taps (85606) | Fuse and Accessories | AutoZone.com
Headlights for alway hot
Radio for key on hot
EGT probe goes in the driver side manifold. Under the truck where manifold an uppipe meet has a nice spot to drill and tap
Fuel pressure will replace the Schrader valve. Youll need a 90* fitting but I don't know the sizes
Old Feb 21, 2012 | 09:48 AM
f350rebel7788
okay, i think i got it... would you happen to have any pics of the probes? I wanna make 100% sure i know what i'm doing before i start drilling...
Old Feb 21, 2012 | 10:54 AM
fordpride's Avatar
fordpride
Under the driver side manifold
Old Feb 21, 2012 | 10:56 AM
fordpride's Avatar
fordpride
You want the tip of the probe to be in the center of the manifold
Old Feb 21, 2012 | 11:02 AM
f350rebel7788
awesome, thanks man!
Old Feb 21, 2012 | 01:59 PM
dclack's Avatar
dclack
Hey, I just installed the same glowshift gauges a couple of weeks ago. First off, the 3 gauge wiring kit is a waste of money. It's only for wiring the sensors as the wiring for the gauge power/lights is already included and the fuel pressure sender is the only sensor that needs wiring. The boost gauge uses tubing and the egt probe comes with stainless braided wiring. The 7.3l fuel pressure adapter is also a waste of money because the sensor will thread right in where the schrader vavle is. As already stated, use a 90* fitting to thread it in. Otherwise, you have to remove the engine lift bracket (which is what I did because I didn't think about the 90* fitting at the time).
I coupled all three gauges together so that I only had one set of wires coming out of the pod.
I found this link helpful as well, especially the last paragraph about wiring.
Gauge Installation - 1994-1997 Power Stroke FAQ
Old Feb 21, 2012 | 03:11 PM
f350rebel7788
that's exactly what i was lookin for! thanks man! beans on the way!
jwilliams41
May 17, 2017 11:13 PM
Gatordog
Dec 11, 2015 05:21 PM
thebig350
38
Feb 9, 2012 08:13 PM
timbo126
Jul 18, 2011 09:31 AM
ryanben
18
Jul 28, 2003 09:01 PM
