what axels?
Old Feb 20, 2012 | 10:08 PM
Farmall05's Avatar
Farmall05
what axels?
ok i have a 95 f250, i want to change the gear reatio in both ft and rear axels but i have no clue what they are, i know the rear is a full floating axel is it the 10.25? and the ft is it a dana 50? i didnt see any tags on eather but know they have 3.55 gears in them
Old Feb 20, 2012 | 10:24 PM
blkF250HD's Avatar
blkF250HD
Correct, the rear is a Sterling 10.25" and the front (assuming its stock TTB) is a Dana 50. The axle code for the rear will be on the sticker in the drivers door jamb.
Old Feb 20, 2012 | 10:30 PM
Farmall05's Avatar
Farmall05
the axel code is 39 if i rember corectly, and it is still the stock ttb, i did wonder if a solid dana 50 from the 99-07 would fit in its place though
Old Feb 21, 2012 | 07:06 AM
tjc transport's Avatar
tjc transport
i ain't rite
the 99 and newer axle uses a different bolt pattern than the 97 an older trucks.
easiest way to tell what ifs axle you have is by the front locking hub size. the D44 ifs has a locking hub slightly smaller than the mounting flange.
the D-50 ifs/D-60 solid axle has a locking hub that is the same size as the mounting flange
Old Feb 21, 2012 | 07:18 AM
Farmall05's Avatar
Farmall05
ok thank you guys very much
mrfix71
27
May 9, 2022 08:58 AM
62FE4x4
16
Sep 29, 2017 07:44 AM
pete17c
May 28, 2010 08:02 PM
shlby123
Jul 21, 2008 03:50 PM
oldhalftons
Jan 17, 2005 04:55 AM
