Rear vent windows
Old Feb 20, 2012 | 11:07 AM
Bundy34's Avatar
Bundy34
Rear vent windows
I have a 1997 EB and my rear vent windows are acting funny.
I can get one good opening and closing from them but then they will slow down and get stop, like they need to cool down before working again. The first time they work they work well.
From reading other posts, I was thinking maybe the relay? if so, where is it?
Thanks
Old Feb 20, 2012 | 01:34 PM
Man_tlac83's Avatar
Man_tlac83
I think this is what your looking http://www.autofuseboxdiagram.com/wp...on-XLT-map.jpg The fuse position is number 29 at the bottom and then go to http://www.autofuseboxdiagram.com/wp...dition-XLT.jpg , this pic shows you where #29 is.
If none of those links work here is the main link. 1997 Ford Expedition XLT Fuse Box Diagram | Auto Fuse Box Diagram
I hope this helps you. I am having the same issues with my 98 but not to worried about it since all my windows work and so does my hot/cold air. Good luck!!!
Old Feb 20, 2012 | 03:43 PM
5.4T's Avatar
5.4T
on my old expedition they also started to act up untill i sprayed them with wd40 then they worked again hope this helps
Old Feb 20, 2012 | 11:33 PM
Bundy34's Avatar
Bundy34
Thanks for the info.
I will see if I can figure anything out with it. I tried to spray it with lube, but it didn't change anything.
I am also having some blend door issues, so need all the windows to work.
MyersJster
Jul 14, 2019 02:57 PM
fastjza80racer
Apr 20, 2016 05:37 PM
johnday
2009 - 2014 F150
Oct 21, 2013 06:28 PM
CRF1966
May 13, 2009 11:28 AM
ltmerrill
Jul 13, 2005 08:50 PM
