Coolant leaking... Help please
Old Feb 20, 2012 | 09:22 AM
Ole Green 1978's Avatar
Ole Green 1978
I replaced my thermostat today and while doing it I flushed the radiator. Filled back up with half coolant/water mix. I am getting a constant drip from up under the fan belt pulley. My hoses are tight heater and radiator. Water outlet is snug. Could this be water pump? If so how bout some pics on how to fix or replace... Thanks!!!
Old Feb 20, 2012 | 09:53 AM
HIO Silver's Avatar
HIO Silver
It could be the water pump. Most have a weep hole on the underside of the snoout where the bearing resides. It starts leaking to inform ya that it is going south... bummer.
Old Feb 20, 2012 | 09:56 AM
Drewmeister's Avatar
Drewmeister
This is likely the problem. You should be able to feel if it's wet behind the pulley. If it is, the seal is probably wiped out because the bushing is worn out.
Old Feb 20, 2012 | 10:05 AM
ctubutis's Avatar
ctubutis
If the leak is coming from the weep hole on the underside of the water pump shaft, my guess is backflushing tickled the bearing/seal area and instigated the leak.
Not because anything is defective, nor am I saying backflushing is a bad idea, just saying your water pump is telling you it wants to be replaced soon.
Old Feb 20, 2012 | 07:27 PM
Ole Green 1978
Thanks for the info. Could anyone break the steps down of replacing it. Also how much is a water pump new?
Jollygr33ngiant
Jan 7, 2016 04:23 PM
Unrealo4
Sep 17, 2011 12:07 PM
fordguy4life
Aerostar
Dec 14, 2006 10:17 AM
wheressinatra
Oct 16, 2006 05:28 PM
RockinB
Dec 22, 2003 10:04 PM
