Aerostar Ford Aerostar
Coolant leak
Old Dec 12, 2006 | 09:54 AM
fordguy4life's Avatar
fordguy4life
Coolant leak
Hey guys. My wife's got a 95 Aero 4.0. I noticed a few drops of coolant leaking the other day towards the front of the engine on the garage floor. Then the next day, Blamo! Big puddle in the garage. The problem i have is it looks like spray, from where the van was parked, coming from the middle of the engine. I did a quick once over and saw no leaks on the top of the engine, radiator or hoses. Saw some coolant on the exhaust pipe by the oil filter. Wasn't able to completely look it over. Any ideas with such limited info?
I did read a few posts about freeze plugs. Yikes!
I'm going to try and take some time to look it over better tonight, so any thoughts are appreciated. Thanks!
Old Dec 12, 2006 | 10:16 AM
96_4wdr's Avatar
96_4wdr
also take a look at the water pump weep hole on the bottom of the water pump shaft housing nose....serves as leak hole for failed seal
good luck
Old Dec 12, 2006 | 05:45 PM
Bear River's Avatar
Bear River
Former ******
There will be scale on the underside of the water pump shaft near the weep hole if it has failed. If this is the case, you need a new water pump. Best way to prevent water pump failure is to replace the antifreeze on a regular schedule like it was your religion.
Old Dec 12, 2006 | 06:04 PM
copper_90680's Avatar
copper_90680
Hi Fordguy:
The easiest thing to do is to fill it up with water and borrow a radiator pump from Autozone. Once you pressurize the radiator, the leak will show up.
Old Dec 12, 2006 | 07:11 PM
thefarelaneman's Avatar
thefarelaneman
I agree with copper. thats the quickest way to zero in on the leak
Old Dec 13, 2006 | 07:51 PM
fordguy4life
Poured more antifreeze in the radiator....started and let run for a few minutes.
Looks like its a head gasket.
Old Dec 14, 2006 | 06:01 AM
RPinNEB's Avatar
RPinNEB
I feel your pain! My '91 4.0 AWD is leaking out of right side headgasket, long time slow leak. Hope to get alternate van up and running next week. After a few runs with van "B" (not a Ford) to be sure it's O.K. I plan on working on the ASTAR. It needs rear brakes, front end declunk and head gaskets. Also thermostat housing has a rusty pipe that needs replaced. Van "A" could be down for awhile. Do you plan on repairing headgasket yourself?
Old Dec 14, 2006 | 06:22 AM
fordguy4life
I wish mine was a slow leak. Antifreeze is coming out pretty fast. The van has 170000 on her. Might be time to put her down. I've heard they're a nightmare to replace, and my mechanic told me at least $ 1000. I'm sure it's pretty labor intensive.
Old Dec 14, 2006 | 07:47 AM
B-Aerostar's Avatar
B-Aerostar
I have a very small coolant leak, but don't know where its at either. I have 252,000 miles. Doesn't run hot or anything. Smell it everytime I start the van. The worst case is the useage of about 1 gallon in a month but now its small again.
Old Dec 14, 2006 | 10:17 AM
copper_90680
Most likely through weep hole on water pump or through a leaky heater core.
Steven111
Dec 21, 2015 01:21 PM
SoCalAngler
Dec 6, 2015 07:08 PM
robvox
Jul 24, 2015 11:24 PM
PSDx3
6.4L Power Stroke Diesel
Jun 28, 2013 09:57 AM
ghanson
Aug 13, 2011 08:55 AM
