Help with a few door codes please
Just got a 1985 F-250 4x4 (HD) for a rehab project. I've got some of the door codes figured out but not all. can anyone fill in the blanks?
TYPE GVW = F268 (F-250 4 x 4 ???)
BODY = KB4 (????)
SPRING = 7K ( I think the 7 is the front springs and the K is the rear
springs)
Other unknowns from Door tag
Direct Special Order Code = 76
Front Axil Accessory Reserve Capacity in pounds = F0403
Total Accessory Reservecapacity in pounds = T0157
Also, can anyone advise what front axil this might have or how I can find out
Rgds
nonrev321
Is it a regular cab? If so, you originally will have a dana44HD ttb unless it was some sort of special order and had the dana 50 ttb If it is a supercab, it will come standard with the dana50 ttb front axle.
~3.25" = D44 TTB
~4" = D50 TTB or D60 solid axle, so look under truck. If the axle pivots in the middle, it is the D50 TTB.
I don't think the D60 was factory available under this model, but it could have been swapped at some point.
TYPE GVW = F268 (F-250 4 x 4 ???) = 1983/ F250 4WD Pickup, 133" WB, 8600 lb. GVWR
BODY = KB4 (????)
KB = Blue cloth & vinyl bench seat on an F150/350
4 = Regular cab w/styleside pickup box
springs)
7 = front = E0TZ-5310-S; Using "before March 13, 1981" specs for a 4WD F250 133" WB using that part number, looks to be 3,860 lb. average capacity at the ground
K = rear = E3TZ-5310-U = can't find any specs on that part number
Google on how to read spring ratings in the trucking industry, look for and read about "at the pad" and "at the ground."
Direct Special Order Code = 76 = Denver
Those don't look like weights to me but rather special-order codes, did you get those from the DSO box?
What are the codes in the AXLE box on the sticker?
Rgds
nonrev321
Source: FoMoCo 1980/89 Light Truck Parts Catalog
I pulled these numbers off the various underbody parts.
Rear Diff: V126A
55 10 2 5C26
Front Differential: P113 5 1 (This was punched into the body)
41582
197
also from a tag that I found on the front differntial
3 54 VE5TA SA
610 31-2
Thanks a bunch
Rear Diff: V126A
55 10 2 5C26
41582
197
3 54 VE5TA SA
610 231-2
Thanks a bunch
Front first (cuz it's what I found first in the catalog):
E5TA-SA:
Dana ID Number: 610231-2
3.54:1 ratio
Dana 44, free-running hub, non-limited slip, 3,850 lb. capacity
OK, rear.
I'm betting there's a "3" to the left of that "55" being covered up by a bolt.
V126-A
3.55 10.25 C26
Ford (Sterling) 3.55:1 ratio
10¼" ring gear
No idea of its capacity, I'd need the AXLE code from the door jamb for that.
Rgds
Vernon
TYPE GVW = F268 // BODY = KB4 // SPRING = 7K ( I think the 7 is the front springs and the K is the rear springs)
= 76This is not what DSO refers to.
Front Axle Accessory Reserve Capacity in pounds = F0403
Total Accessory Reserve capacity in pounds = T0157
FoMoCo usage only, cannot be decoded.
KB4: KB = Blue Cloth & Vinyl / 4 = Styleside Pickup.
76 = Denver CO Ford District Sales Office .. where the original selling dealer ordered the truck from.
This truck was not a Domestic Special Order, because the DSO code only contains 2 digits. 6 digit DSO = Domestic Special Order.
V126-A = Ford (Sterling) WDD 10.25" Full Float Rear Axle / 3.55-1 / non Limited Slip / 6,250 lb. Rear Axle Capacity.
Chris: No need um Certification Label Axle Code, because you have: V126-A = Text, Section 40, page 18: Parts List #258 = WDD
Now look up F250 WDD rear axle in the application charts, the axle capacity is listed.
OK, I see 3 possibilities, how do I know which is his?
Seriously, some of the stuff is self explanatory but some things I'd like to know.
WB= Wheelbase, which is 155"
X268 I'm assuming is F250 Super Cab
Body KDM... ???
Trans K = C6
Axle 35 = 4.10 open.
Tape 3... ???
Spring 7 K - As listed above.
Then there's the 1C 1G part. Paint codes?
DSO 13? Where did they send my truck originally?
Also, what are the F0351 and T0119 codes?
What I can say real fast....
The F & T codes can't be decoded to anything, I believe that was special-order information used internally at the factory.
1C & 1G are two colors, this means your truck came as a two-tone.
The rest of it, I will have to go to the book...................
I found 1G is Light Smoke Metallic and 1C is Black.
Is there any way to tell how the truck was painted? It's all black now.
I found this diagram for the 86
