3 on tree 5 speed help
Old Feb 18, 2012 | 04:29 PM
smallblock9466's Avatar
smallblock9466
i have a 3 on the tree on my 69 f100 i want to put a 4 or 5 speed on the floor in my truck it currently is 2wd and has a 302 in it i cant seem to find a detailed thread on this. please help
Old Feb 18, 2012 | 04:38 PM
85e150's Avatar
85e150
There are several choices here, depending on what you have, what you are doing, what you hope to accomplish.
--your 302--is it a stocker, or a firebreather?
--are you looking to tow and haul? Light or heavy?
--budget? You looking for stuff alongside the road, or have some money to play with?
Here are two links to transmissions. The first is a general list, and your choices are the Ford 4 speed OD, the BW T18, T19, the NP435, the Mazda 5 speed and the ZF 5er:
Domestic Truck Tranny Guide
The second has specific ratio info for the 4 speeds:
The Novak Conversions Transmission Information Gateway
You may have to move around on that site to get the more detailed info.
Old Feb 18, 2012 | 08:21 PM
smallblock9466
wow thats awesome thank you for the information.
well shes not a fire breather but she aint stock, cam, headers, carb, intake, soon to have 10:1 heads, this truck is going to be my DD and weekend warrior/work horse.
i want to race around with the truck when i want but be able to use it like a truck when needed.
i have the 9in rear with i think 305 gears (i plan to trade those out asap)
im looking at a t5 from a 1987 Ford T-Bird Cougar 2.3L Turbo and one from a 1992 Ford Mustang 2.3L but but i thought i need one from a 302 like mine. thanks again.
Old Feb 18, 2012 | 08:41 PM
85e150's Avatar
85e150
I think you meant 3.50 gears. What do you want to change them to?
A T5 will work, but is not intended for heavier weights and towing. The 4 cylinder models will have very low first gears. A Mustang "World Class" box would be better. Some have a 3.35 first. Info here:
Ford Mustang: Mustang Tech: Transmission and Drivetrain: Borg Warner T5 Transmission data
This outfit has adapters and other info/parts:
Modern Driveline - TREMEC T5 / TKO Transmission Conversion - 5 speed & 6 speed solutions to swap your Ford Mustang, Falcon, Cobra, Hotrod into Overdrive! Performance Parts
I can get you some other links, but gotta go right now.
Remember also, 5th is a bit tall, so if you have a short tire or want to go to 3.89s or something, that will be in your favor.
Old Feb 18, 2012 | 10:17 PM
HIO Silver's Avatar
HIO Silver
Some sources for information and resource:
Specialty Performance Parts, 5 and 6 speed Transmission Conversions and Accessories
Keisler Engineering
Old Feb 18, 2012 | 10:24 PM
70-360fe's Avatar
70-360fe
The Ultimate T-5 Swap Article
Old Feb 19, 2012 | 07:01 PM
smallblock9466
nice ncie thank you all very much
Old Feb 19, 2012 | 07:02 PM
smallblock9466
im not sure what gear im going with but i figured what i have now is to low
Old Feb 19, 2012 | 08:54 PM
HIO Silver's Avatar
HIO Silver
Keep in mind the final drive ratio if going with an overdrive by multiplying the OD gear and the rear end ratio. For example, a 0.68 fifth gear and a 4.10 rear gear equals an effective ratio of 2.79 which is a good highway gear.
Old Feb 20, 2012 | 10:02 AM
Freightrain's Avatar
Freightrain
Unless it was changed, likely it will be only a 3.50 rear ratio(commonly), so it will be 2.38 final drive ratio. If you cruise at 2700 rpm at 70 mph, then you'll drop to 1836 rpm at 70 mph.
As long as you have enough power to pull the truck at 1800 rpm, it will help. If you have hilly terrain, then you'll be shifting back and forth a lot.
Old Feb 20, 2012 | 06:05 PM
smallblock9466
thank you both, yeah i have the power and i was thinking of the 4:10 gears
AlsRyd66
May 24, 2019 06:31 AM
jondeuce
Dec 20, 2016 02:23 PM
Clay101196
43
May 15, 2014 12:55 PM
Ron_CNY
Sep 24, 2004 11:53 PM
laptopgeek
May 8, 2001 06:50 PM
