knocking front axle
Old Feb 18, 2012 | 03:21 PM
tdbronco77's Avatar
tdbronco77
knocking front axle
I have a 94 f-250 supercab 5.8L auto 4X4, at 54 mph and up there is a intermitant knocking coming from the front axle (D50), I have replaced all of the u-joints because thats what the noise sounds like but hasn't seemed to help. I've run it with the front drivshaft off just to make sure it wasnt that and it's still there, Im at wits end here and am not sure what to do next. Is it the wheel bearings or maybe spindle bearing? Any help would be greatly apriciated.
Old Feb 18, 2012 | 06:49 PM
F-250 WARHORSE's Avatar
F-250 WARHORSE
Take a bar and pry up on the ball joints and see if you can see any play, they can clunk sometimes if bad.
Old Feb 18, 2012 | 07:19 PM
danr1's Avatar
danr1
Are the retainers for the calipers good, fit in the slots snug?
Caliper should be held firm, not allowed to drift up/down or rock in/out on those retainers, if they do replace them.
If not will allow caliper to rock back and forth creating a knocking sound, bumps and or with "wheel/rim hobble" at a given speed.
Example; NAPA part number UP 82471W slides only (one side).
Kit UP 82824A includes slides for both sides and with anti rattle spring for the pads.
Old Feb 18, 2012 | 07:47 PM
tdbronco77's Avatar
tdbronco77
I dont think its the brake caliper because it still knocks with the brakes on at speed and i'll have to check the balljoints in the morning. I just find it strange that it only knocks at 54mph +. thanks for the replys.
Old Feb 18, 2012 | 08:59 PM
F-250 WARHORSE
Could be ball joints, wheel bearings, spindle bearings, tie rods, loose hub cap, spring bushings, brakes, I would start at the ball joints, then lay under the truck with good light and have someone steer back and forth on the wheel while you arelooking at the front end and look for anything moving, look at ball joints, tie rods, pitman arm, bearing hubs, u joints, spring bushings, if it looks like something is loose put your hand on it and feel for movement with wheel being jerked back and forth.
Old Feb 18, 2012 | 09:18 PM
danr1's Avatar
danr1
Unlikely its the calipers as the it still makes the noise when the brakes are applied. Under a hard braking condition yea would prevent any noise. Severely worn/soft retainers though under light braking condition can and will bang/knock, if the rotor/s suffer runout distance that translate onto caliper/s positioning. May or may not feel some pedal pulse because of it.
Might prove easier help narrow down the problem if helpers here could hear it too, if could post video with sound while its happening.
Has to be something unloaded or at least partially unloaded at speed.
Old Feb 19, 2012 | 02:54 PM
tdbronco77's Avatar
tdbronco77
Well guys thanx for the help, the stupid F'ing retaining screw on the locking hub was loose and now its fixed.
Spktyr
Sep 9, 2012 06:30 PM
tbirdage
Dec 21, 2009 02:06 PM
easpilman
Dec 19, 2006 08:56 PM
MatthewC
1978 - 1996 Big Bronco
Jul 26, 2004 02:11 PM
donnie88
Dec 8, 2000 09:02 AM
