bad clicking on right front
i have an 88 bronco i have a noise that has came on strong
recently.it is a clicking sound that at times can be aloud
cluck.it is coming from the right front.i changed the lower
ball joint it was alittle weak but not what i would call bad
and new bearing and seal while i was there,but no help.
any ideas or help.
thanks
donnie
`88 eb 5.8
33 bfg mt
no lift
any ideas or help.
thanks
donnie
`88 eb 5.8
33 bfg mt
no lift
If it's a full-time, axle u-joint, might also be the "spring" that holds the caliper up against the top. This might be gettin' weak and allowing the caliper to "bounce" up and down. One other thing it might be is the spindle bearings that the axle rides in/on. This would only be with full-time or when the front end is locked in.
