Help decode VIN & info on data plate
Old Feb 18, 2012 | 07:05 AM
19fifty4's Avatar
19fifty4
F1R2AT-25385.
Color = N (is this meadow green?).
26A = ?
Production code = 864D
I know its a 52 but what else do the numbers tell me?
Thanks,
Old Feb 18, 2012 | 08:07 AM
mtflat's Avatar
mtflat
Originally Posted by 19fifty4
F1R2AT-25385.
26A = ?
Thanks,
Half-ton, V8, 52 Atlanta assembly plant - serial number 25385
Color - Meadow Green
26A - doesn't correspond to anything I have. What is it located over? Trans/Axle/ etc??
Production code is assembly plant specific - only they knew
Old Feb 18, 2012 | 10:55 AM
51PanelMan's Avatar
51PanelMan
Tim is right on the decode.
However, I like to see the serial data tag decoded like this. I think that it helps some people see it this way.
F1 = 1/2 ton
R = 239 V8 flathead
2 = 1952
AT = Atlanta assembly plant
25385 - serial/production number down the line
Old Feb 18, 2012 | 12:13 PM
19fifty4's Avatar
19fifty4
Thanks for the help. The bottom portion of the data plate reads:
Trans = 3.
Rear Axle = 3.92.
Color =N.
26A.
Production Code 864D.
All the numbers line up directly over the corresponding description with the exception of 26A. It's not really aligned with anything. Curious what the 864D might stand for.
Old Feb 18, 2012 | 12:23 PM
51PanelMan's Avatar
51PanelMan
Trans = 3.
Rear Axle = 3.92.
Color =N.
26A.
Trans = 3 speed
Rear Axle = 3.92 gear ratio
Color = N (Meadow Green)
26A = January 26 ???????
Production Code 864D = ???????
puranga
Oct 12, 2012 01:56 PM
jgurland
Feb 7, 2008 08:51 AM
dennisb56
Mar 4, 2007 10:58 AM
ksmith203
Jan 17, 2007 10:33 AM
57custom
May 22, 2004 04:45 PM
