Power Source (And lights?) for Heated Mirrors...
I need a power source for heated mirrors. I was told they draw roughly 1.5amps. I have some good 12ga automotive wiring, and a 10amp on/off toggle switch.
The plan is to run the wire from the power...to the switch, then 2 wires to the mirrors from the switch, then ground out the negative from the mirror.
My current thought is to get a fuse piggy-back, run the power from the fuse box, and run a in-line 5amp fuse before the switch.
Any better ideas? Or better places to get a key-on power source?
Also, does anyone have a wiring schematic or color-code list for the wiring harness in an 02?
I THINK I know which wires to tap for the blinkers/parking lights... but I'd like to be sure.
Thanks in advance!
Thanks in advance!
