General Automotive Discussion
Help with commuter car!!
Old Feb 17, 2012 | 08:35 PM
sniswend's Avatar
sniswend
I am an owner of a 2007 f150 with the Triton 5.4. I have used this truck as my commuter vehicle for 3 years and it was getting expensive. I recently bought a 1999 Ford Escort Zx2 with an over head cam 4 banger and an automatic tanny. The car has 85,000 miles on it.
Anyway I had to change the battery this week and ever since then the car has been acting strange. Every time I come to a stop the car revs into first gear. When I am going about 5 MPH with the break on the car revs up to about 1500 RPMs and hits first gear. This causes the car to lung forward as I am trying to stop. I was wondering if anyone out there owns a car like this and knows if it needs some sort of "reprogramming" after the battery has been unplugged? Any help would be great!!
Old Feb 17, 2012 | 11:13 PM
Ford_Six's Avatar
Ford_Six
If the old battery was boiled out, then chances are very good the alternator is putting out a/c. To check the output of the alternator for a/c, just set your meter to read AC volts, and with the engine running touch one probe to the alternator output and the other to a handy ground spot like the head or even alternator case. If it's over .1v ac I replace the diodes if available or replace the alternator. I have seen this cause a phantom revving problem on a Volvo 850, it was an interesting problem to track down.
Old Feb 18, 2012 | 02:20 AM
732t37's Avatar
732t37
Ford6, sounds like you got it. Just wanted to add another (less likely) cause that may be possible: Overrunning clutch is no good?
rebar13
Dec 29, 2014 01:20 PM
askim
Electrical Systems/Wiring
21
Jun 10, 2010 09:35 PM
Garden Spyder
Kansas Chapter
19
Sep 27, 2009 09:19 AM
bryan_johnson
16
Feb 16, 2006 12:00 PM
blaisesdaddy
Nov 12, 2004 11:15 AM
